Question about GVision J7PH 17.1 in. Flat Panel LCD Monitor
Monitor is shutting off after a two seconds
I have a j7ph-ta 17.1 Touch Screen I bought for $10 because when you hook it up it will come on full and clear for two seconds, beep then turn black. The green light is indicating that it is on and has a signal is still on. If you turn it off and then back on then it will do the same thing again.
I have tried:
Changing resolution down to 800x600
Changing the refresh rate in windows
Several computers; all the same reaction
Installing drivers for the touch function while
So I don't know where else to start with the troubleshooting. Any ideas?
    Master:
  • 923 Answers
What is the make and model and type of the monitor? Is it an LCD type, an LED type, or a CRT (cathode ray tube) type, which looks like an old picture tube?
Posted on Apr 20, 2017
IrishDruid
  • 2712 Answers
SOURCE: Problem with my LG monitor L194WT
First change the referesh rate for your monitor. If that works, then you dont have to change the resolution. If that does not work, try increasing the rate again. Once you can get the game, then try to change the resolution from within the game options, if necessary..
Posted on May 27, 2008
russolini
  • 47 Answers
SOURCE: Many screens on one monitor!
Your monitor is malfunctioning and requires servicing. Unfortunately there is no software solution, and no monitor adjustment buttons will control this problem. Due to the high cost of replacement parts and service technicians, it may be more cost effective to buy a new LCD monitor. Sorry to be the bearer of bad news :(
Posted on Jun 10, 2008
  • 109 Answers
SOURCE: Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Posted on Oct 29, 2009
Randyincv
  • 17 Answers
SOURCE: Had the blank screen problem. Now it won't work above 800x600 res
The case is a PITA to pop apart, I use plastic Guitar pics to release the latches to separate the case, this works VERY well and doesn't mar the plastic on the case seam. Patience, and don't use excessive force...
Replacing the 6 Caps fixed my monitor..
Before you start, pay close attention to the orientation of the connecting Cable between boards, it's NOT Keyed. Mine had White Bands on the connectors that faced the Chassis when the Board was mounted.
There seems to be different versions of Bords depending upon production dates.
Some of these Monitors do have:
(1) 470 uf @ 10V
(3) 470 uf @ 25V
(2) 1000 uf @10V
I replaced them with:
(4) Radio Shack 272-1030 470 uf @ 35V
(2) Radio Shack 272-1032 1000 uf @35V
$8.34 Saved an Expensive monitor.
I would prefer to use Higher Quality Caps, like the Panasonic Caps from Digikey, but this worked in a pinch. The higher Voltage should make the inverter board a little More Robust.
Good Luck
Posted on Jan 27, 2010
SOURCE: L5PX S5PX-TA-AU41N-2001-ULX (RES) SERIAL NUMBER: 15NG50200119 HI.
don't give me that shittt.
Posted on Jan 15, 2013
I just hoolked up a Kogi l7 eh 17
It may be that your video card is too old, that probably is the problem since you are running Windows 2k. If not open up your monitor's menu and see if you can manually change the monitor's resolution. Newer monitors do that.
Apr 12, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Elo 17" LCD Touch screen ET1725L Powers off after 1 second
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Jim
Oct 28, 2008 | Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X...
Kogi l7eh-ta ko 17 in
It looks like your power supply is shutting down (terminal overload shutdown) due to excessive current consumption. You need to get a power supply that meets the voltage and current requirements of that monitor or greater current reuirements.
Sep 03, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
HP Pavilion dv9000z 17" Problem with monitor turning off
if you are clueless in this, better not to touch anything. The only thing you can do is reinstall the operative system, after backing up you files of course, so you will make sure the problem does not come from software. If the screen still failing you have to either repare it (which inplies disassembling) or replace it. In the first case i repeat, if you are clueless, better not to touch anything... and in the second case you should take it to an hp authorized technical service. It might be expensive but otherwise you could end up with a broken laptop.
Aug 11, 2008 | HP Pavilion dv9000z Notebook
Elo Touch Screen wont stay on!!
Hoya
I spoke with ELO techsupport and they said that I have a bad backlight inverter. I am looking for replacement parts. Have you found anything? If not, would you be interested in selling your USB controller unit from your monitor? Wake
Jul 08, 2008 | Elotouch 17" LCD Monitor
No video
sounds like the backlight in the monitor have you tried another monitor?
May 25, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Screen size
please refer owner manual which must have come along with your monitor at the time of purchase or call tech from where you have bought if it is under warranty
Sep 28, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
GVision J7PH 17.1 in. Flat Panel LCD Monitor Logo
49 people viewed this question
Top GVision Computers & Internet Experts
David Payne
David Payne
Are you a GVision Computer and Internet Expert? Answer questions, earn points and help others
