Question about Maytag Kitchen Ranges
Taking the top off of a Maytag MGR6875ADW gemini
How to take the cooking surface top off?
fridgetech
  • 473 Answers
SOURCE: Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad.  F1-2 would be for the lower oven and F1-1 would mean the upper oven.  If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price.  These are very easy to replace.  Should be located inside the oven in the upper right or left hand side.  It looks like a silver rod about 4-8 inches long and crimped on the end.  Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done.  Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above.  Hope this helps.
Posted on Oct 19, 2007
Master_Tech
  • 770 Answers
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
ohms, wiring, control
F1-8 Keypad Shorted Replace Control
Here is the link for you to print off the service manual on your range
http://www.servicematters.com/maytag_library/docs/16010107.pdf
PLZ Rate my service
Posted on Feb 17, 2008
  • 68 Answers
SOURCE: My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
Posted on May 01, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
Hi i have a maytag gemini model # mgr6875adw and the lower oven doesnt heat up the upper will only heat up if we turn the broil on for a couple of minuntes this does not work with the lower oven
Sounds like either the fuse is blown on the back of the oven or the switch to set the oven is pooched.... also you may try just have flipped one side of the 220 breaker in the basement..... look for a pair of dedicated breakers or fuses on the fuse box in your home and see if the two fuses( 110 each to make 220) are working
Oct 17, 2014 | Ovens
CERAMIC COOK STOVE TOP CRACKED
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Feb 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I want to remove the cook top off my Maytag Gemini range to replace a part. How do I lift the cburner cooktop. MGR6772BDS
there are two very small screws on the corners above the door, some times more along the whole front
once removed your top will flip right up
Sep 29, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Gemini range: Back left on range top does not
Check the surface element for continuity.
Check the surface element receptacle for a good contact and voltage..
Check the surface element switch for voltage and continuity.
Mar 09, 2009 | Maytag MER6549 Gemini Electric Kitchen...
Gemini electric oven; glass top cracked
yes its not too difficult check your owners manuel as most ceramic cook tops are under extended warrenties from 5-10 years
Feb 11, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
What is the building code for the distance from the bottom of the microwave to the cooking surface below? I have a Maytag microwave that was manufactured in May 2002 and a Maytag Gemini gas cooking stove.
You can check the owner's manual or installation instructions for what the manufacturer stipulates.
If you don't have them, you can download them here.
For building codes, contact your county or city government offices.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Maytag Microwave Ovens
Top of Gemini range
Hello patricialc,
Welcome,
You said, you have the stainless Gemini range and the top is black. I cannot get the top clean. It looks like the paint or the surface is "bubbled". I have tried EVERYTHING and it always looks like there is grease spatters on the top. I have all Maytag appliances and I am VERY disappointed with this stove. If I could, I would take it back...but I keep trying. I let the Maytag stove I had go. It was made in the late '50's, so I could 'update'. What a mistake!!!
The other option is to order a new glass top and have it replaced.
No abrasives!!
Let me know how you do.
Huuum
Please remember to leave a rating!
Jun 29, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
PLZ Rate my service
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
67 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
