Question about Canon DR-2050C Path-Through Scanner
Page 2 of document is dirty
Page 2 of scanned document has lines through it/looks dirty. How do I clean scanner?
SOURCE: Black line down middle of scan
Well I hate to give out bad news but if that line is in the exact same location on every scan it means that the element (the scanning light) has failed. Sorry that I could not earn a FixYa for you. If you need to replace the scanner I have had excellent luck with Epson scanners. Here is a link to a few on Amazon.com for refrence.
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps
&field-keywords=epson+scanner&x=0&y=0
Just copy the link and paste it into your web browser. there are also some very good all in one options. I have had this one for a year and it works well:
http://www.amazon.com/C7280-Photosmart-All-Printer-CC567A
/dp/B000UY6M2G/ref=pd_bbs_sr_4?ie=UTF8&s=office-products
&qid=1210270089&sr=8-4
Hope that was at least helpful.
Take Care,
-WN
Posted on May 08, 2008
zohail
  • 1223 Answers
SOURCE: Lines on scanned documents
pls update the driver
http://canon.driversdown.com/Canon-driver-list/s_421_1.shtml
pls clean the scan glass , if it helps otherwise
ur CCD engine inside the scanner is weak now after use there is no point in getting it replaced as it is not worth pls find a new scanner
HP are excellent and MUSTEK are good and economical
pls rate me if i diagnosed ur fault
Posted on Mar 09, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
S. Mohan, Chennai, India
Posted on Mar 18, 2009
mohanchennai
  • 490 Answers
SOURCE: Getting vertical lines on scanned pages when
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Posted on Jul 10, 2009
mohanchennai
  • 490 Answers
SOURCE: I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Posted on Jul 21, 2009
Lines on scanned page
Could be the scanner is hesitating as the carriage moves - bad gears perhaps. Hhave you thoroughly cleaned the glass and wiped it dry? Is the scanner level andand fully unlocked? I would try these quick fixes first. If they don't work, scanners are cheap nowadays.
Oct 18, 2012 | Umax Astra 3400 Flatbed Scanner
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Every time I try to batch scanning on my Pixma MP530 I get a vertical line running through the page. I've cleaned the platen glass, the inner side of the document cover, the transparent sheet (I even...
When using the ADF to scan multiple document the scanner assembly stay stationary and the paper is fed across it. Where the scanner parks for this there is something between the scanner and the document, likely on the glass. Often there is a small strip of glass on one end of the scanner bed. Clean here if there is one, otherwise look around and I'm sure you'll find it. Remember, never spray cleaning solutions directly onto the glass, always onto a cloth or towel first. The scanner has a calibration strip that can be damaged otherwise.
Feb 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon DR-2050C Path-Through Scanner Logo
35 people viewed this question
old marine
old marine
