Question about Weiser Lock Powerbolt 1000 Lock
Programming lock re program lock
  • 963 Answers
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Feb 22, 2012
How to program New key switch 2000 oldsmobile silhouette
Key switch ? key fob ? Transmitter Programming ?
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important: Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
  1. Remove the ignition key from the ignition lock cylinder.
  2. Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
  3. Close all of the doors.
  4. Close the lift gate.
  5. Turn the ignition lock cylinder to ACC.
  6. Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
  7. Open and close any vehicle door.
  8. A chime will be heard when the system enters the BCM programming/diagnostic mode.
    Important: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  9. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
  10. Repeat the previous step on each additional transmitter to be programmed.
  11. Remove the ignition key from the ignition lock cylinder.
  12. Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
Apr 22, 2016 | Oldsmobile Cars & Trucks
How to program a new alarm remote
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation .
Hope this helps, I found it online
-Scott
Feb 19, 2015 | 2004 Pontiac Grand Prix
How can I program a key fob
GRAND PRIX KEY FOB PROGRAMMING INSTRUCTIONS Transmitter Programming No Tools Required In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver.Up to 4 transmitters may be programmed Important Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver
Apr 22, 2013 | 2001 Pontiac Grand Am SE
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
No Tools Required
Important
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Important
Hope helps.
Jul 16, 2010 | 2001 Pontiac Grand Am SE
Central locking on mk 5 golf works fine with key in lock and from inside car using switch but only unlocks drivers side using key fob. any answers?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Polo: Press key unlock button for approximately 1 second. Golf/Bora: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction.
How - Polo
Keys can only be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed.
How - Golf/Bora
98MY
How - Golf/Bora 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Mar 07, 2010 | 2001 Volkswagen Golf
Replaced battery now having problems with automatically locks
Synchronization
When
How
Programming
When
How -
98MY
How - 99MY
Feb 05, 2010 | 2002 Volkswagen Passat
How do you program the remotes for keyless entry with a 200 pontiac grand am?
No Tools Required
Important
Important
Oct 21, 2009 | 2000 Pontiac Grand Am GT
Can't program keyless entry remote.
Try this,
No Tools Required
Important
Important
Good luck and hope this helps.
Jun 23, 2009 | 1995 Cadillac DeVille
THE REMOTE DOOR LOCK ON A 2000 BUICK CENTURY HAS QUITE WORKING. THE FOBS ARE GOOD BUT WON'T OPEN ANYTHING.
The transmitter may have lost programming,
IMPORTANT:
  • Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
  • Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
  1. Sit in the driver's seat.
  2. Remove the ignition key from the ignition lock cylinder.
  3. Close all vehicle doors.
  4. Press and hold unlock on the door lock switch.
  5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
  6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
  7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
  8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds . You will hear two chimes. This chime feedback indicates that the transmitter has been programmed successfully.
  9. Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
  10. Exit this procedure by removing the ignition key from the ignition lock cylinder.
May 07, 2009 | 2000 Buick Century
Car key remote
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Mar 24, 2009 | 2001 Ford Expedition
Weiser Lock Powerbolt 1000 Lock Logo
59 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
