Question about ASUS N71JQ-XT1 17.3" Brown Laptop PC Notebook
Reboot & select proper boot device or insert boot media in selected boot device?
  • 10 Answers
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
Posted on Jun 17, 2009
  • 39 Answers
SOURCE: How can i reboot my laptop?
It is either not seeing the HDD and/or the boot sector on the hdd has been damaged. Any repair you do will only be possible after you boot to an environment. If you can get a bootable CD made, that would be one option. Bootable USB is another. Once booted, you will then be able to examine the HDD to see what the problem is.
Does the bios show a HDD at all?
Posted on Jun 06, 2010
sim4182
  • 393 Answers
SOURCE: reboot and select proper boot device or insert
check 1st is there any memory card plugin or not if plug then remove and restart the system 2nd install operating system .. if same then repalce hdd.. thanks...
Posted on Sep 14, 2010
SOURCE: when I turn on it says Reboot and select proper
This problems would most likely be caused because of your boot order has been changed in the BIOS settings. If you have a floppy drive as your first boot device and your CD ROM as your first boot device, your computer will try and find media on these devices to boot from, if you don't have anything in the drive this will happen as it did"Reboot and select proper boot device or insert boot media in selected boot device and press a key" this just means that your hard drive that has your operation system installed is not your primary boot device, however it should be. To change this you need to enter BIOS set up and find where these settings are and change your boot order so that your hard drive with your operating system is installed on is the first boot drive, as for your second boot drive, its really your choice.
Boot and hold F2 to get to BIOS,next Go to Exit tab and choose Load Setup Defaults.Exit and Save.
Posted on Mar 08, 2011
  • 51 Answers
SOURCE: reboot and select proper boot device or insert boot media in selected boot device and press a key? please help me proceed from this screen when starting pc.
Try putting in your windows disk and using the repair option, your hard drive could be bad or data corrupted, you may have to reinstall windows if you are unable to recover it using the repair console. run CHKDSK /p from the C:\ prompt in the repair console. If you still are unable to access the disk, try reseating the cables on the drive, or using a different power cable. If none of that works, replace the hard drive.
Posted on Nov 26, 2011
G31M-VS reboot and select proper boot device or insert boot media
check whether the hard drive is detecting or not, select the first boot device as hard disk
Feb 02, 2013 | Computers & Internet
Np350U5C-903AU
Go into the BIOS setup and then the boot up device and select the hard disk as the first boot device.
Jan 22, 2013 | Samsung Computers & Internet
Emachine wants to: " reboot an select proper boot device or insert boot media in selected boot device an press any key " . I dont have a boot media or know what is the proper doot device....
The proper boot device is your hard drive, when you boot hit F2 while it is booting up and it will bring up the screen to change boot devices select the hard drive and save the settings and this should work if it dont it is possible that your hard drive has bit the dust.
B52computers
Jan 14, 2011 | E-Machines eMachines Desktop PC
GETTING ERROR: REBOOT AND SELECT PROPER BOOT DEVICE OR INSERT BOOT MEDIA IN SELECTED BOOT DEVICE. WHAT DO I DO?
its not detecting your HDD. on boot enter BIOS & check whether your HDD is being detected by the MB. IF not(most possible) then check the power & data cables to your HDD, Check your SMPS too, if SMPS OK then your HDD is corrupted. GET new HDD
Jan 01, 2011 | Gateway 552GE PC Desktop
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
Computer beeping and saying reboot and select proper boot device
Jun 04, 2009 | ASUS Eee PC 1000H Laptop
When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
May 27, 2009 | MSI MEGABOOK M510C Notebook
My pc crashed and on restart it asks for me to reboot and select proper boot device OR insert boot media in selected boot device and press a key- I don't have the boot media c d and can no longer get
Listed below is link to HP drivers page for M270. The recovery Windows Media Center CD is no longer availabe for purchase. If you have a license copy of Windows XP you can install then download remaing drivers from link listed below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=339679
Apr 29, 2009 | HP Computers & Internet
ASUS N71JQ-XT1 17.3" Brown Laptop PC Notebook Logo
96 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
