Question about Dewalt Plumbing
Restoring duro E500 water pump
Duro
Where can I find a Duro 130/90-10 61 J Tubless
Duro Front or Rear HF290 130/90J-10 Blackwall Tire - 25 ...
https://www.denniskirk.com/duro/front-or-rear-hf290.../543621.sku
Duro Front or Rear HF290 130/90J-10 Blackwall Tire - 25-29010 ... and stability;Tubeless; Blackwall; Sidewall ID Information: Duro HF290 130/90-10 61J.
Bicycle tubeless tire 130 / 90-10 61 J HF-290
global.rakuten.com > ... > Tires > Scooter Tires > Below 10 Inch
Product name, 130/90-10 Duro DURO-inch tires. Manufacturers, DURO (Duro)-. Fits size, 130/90-10. Accessories, Without. And DURO, DURO tire E marked ...
Oct 29, 2015 | Computers & Internet
I have a 2006 Mitsubishi Raider Duro Cross 6V. I'm
prob a clogged drain. get in there under the hood with small poke tool and ream out the drain rubber pipe. may be calcium buildup.. ie, hard water..
Dec 13, 2017 | Cars & Trucks
How do I reformat a compaq armada e500 lap top
Use the Restoration Disk.
Perform a Repair if you are going to keep existing personal information.
(i.e., Documents you have created or downloaded, Photos, Music, and programs you have downloaded, or installed)
Repair is a Non-Destructive Installation.
Perform a Full Installation if you do not plan on keeping personal information.
Full Installation is a Destructive Installation.
If you do not have the Restoration Disk for your Compaq Armada E500, you can obtain it from HP Support. (HP owns Compaq)
In the USA the Restoration Disk is free.
The shipping and handling is not.
$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Call 1-800-474-6836
(24hrs a day, 7 days a week)
For all other countries please click on this link,
http://www8.hp.com/us/en/hp-information/summary/ww-support.html
If you format the harddrive the wrong way, you will wipe off the Windows operating system.
You'll have a blank harddrive.
Regards,
joecoolvette
Jul 05, 2011 | Compaq Armada E500 Notebook
How far will a 1 HP jet pump jet.will it jet at 125feet.if so how much gpm and what size jet do I need
That is quite a large distance to pump for most electric pumps. We had a gas 8-10 HP firepump which was used to pump out of several 6" steel cased drilled wells on a ranch. It was a KUBOTA with high performance " high head" design which gave both lots of water for fire control and the ability to do the work of raising water a long way up a hill if needed. The clearance between the impeller and the case needs to be very small so expensive machining is involved, possibly even "Crane" seals with spring loading and sliding nitrite discs instead of just a bronze bushing in a so-so aluminum casting. All pumps will have specs for GPM but they shy away from giving you a graph of GPM versus Pump Head at those 125 foot amounts, the KUBOTA states the chart right away since it is a very high GPM pump in those high water lift conditions. Residential jet pumps just build designs for a lift of 40 feet or less so they might even stall out at half of your requirements. You might even think of the old DURO pumps from CANADA with a 1/3 HP GE motor and use two pump houses with electric power and small 20 gallon steel pressure tanks to relay the water in three steps from the source. I purchased two of them for rebuild for $50 and you can fix them up easily using Generic Chinese piston pump parts which are an almost exact fit copy of the DURO.
Jun 04, 2011 | Hardware & Accessories
How do you refresh compaq armada E500?
what do u mean by refresh ?
1. restart
2. restore
3. refresh screen
Dec 31, 2009 | Compaq Armada E500 Notebook
I have never taken a Duro piston pump apart, It is used to pump water from well to house, lift 25 feet run 200 feet, I would like to find a kit and put in but also have a manual to see how to repair it is...
I solved it by continueing my search and one gentleman sent me a manual and added information at no charge. gee it seems there are more experts, a has been underpressure, that want a fee then good advice and knowledge for free, what a world we have created
Dec 13, 2009 | Plumbing
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
PRODUCT ID NUMBER
Look underneath your laptop,theres is a sticker with number on it. usually 25 characters long.
Feb 18, 2008 | Compaq Armada E500 Notebook
Plumbing Logo
87 people viewed this question
Top Dewalt Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Dewalt Plumbing Expert? Answer questions, earn points and help others
