Question about Canon imageRUNNER C3200 Color Printer
Canon IR 3100cn
How can I determine or set the ip of the machine?
Or where I can download the network guide manual for this machine?
I only have the user's guide
  • 849 Answers
My canon image runner 4005 (ir 330-405f) was connected to a network while i was formating my syste. The ip got deleted in it. What should i do?
check with network administrator for new ip or goto network settings and fetch ip by using DHCP.off/on the machine and thats it.
Sep 18, 2011 | Canon imageRUNNER 400S Copier
How to know ip adress for Canon ir c6800
Network settings are in the additional functions> system settting > network settings. If your printing to the copier the ip address should be there in the network settings.
May 13, 2010 | Canon imageRUNNER C6800 Copier
Ir c3200 is offline
Check that network settings are still correct in system settings. If they are then power down the machine for 10 seconds and restart it. Wait for 10 minutes to see if it comes online. Try pinging it from a pc on the network to see if it can be seen - to help determine if there is a faulty network card in the machine. Pinging means entering the DOS screen and typing 'PING (SPACE) 'IP ADDRESS OF MACHINE' then enter.
You should get some response if it's connected ending with a number like TTL225 etc. Check that there are no error messages on the machine itself causing it to force itself offline.
Nov 09, 2009 | Canon imageRUNNER C3200 Copier
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Jan 20, 2009 | Canon iRC3100 Printer
Ok. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
Nov 12, 2008 | Canon imageRUNNER C3200 Color Printer
Network Problem
To set change your IP you press the star button,then you go to system settings,network settings,TCPIP settings,there you enter IP.
Oct 27, 2008 | Office Equipment & Supplies
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER C3200 Color Printer Logo
139 people viewed this question
old marine
old marine
