Question about Apple iPhone Smartphone
My iphone3 is disable
Passcode tried many times
The only way you can do is call up to apple and they can activate it back to normal or you may plug your IPhone into your laptop using a USB cable. Once Itune have open hold the top right button and home until the Itune logo have pop up on your IPhone screen and just restore in.
Posted on Feb 20, 2012
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
Ipad forgotten password
From the apple support site:
iOS: Forgotten passcode or device disabled after entering wrong passcode When you set up a passcode to secure the use of your iPhone, iPad, or iPod touch and then enter the wrong passcode, you may see a a message saying your device is "disabled". Learn what to do if you have forgotten or can't remember your passcode, or if your device displays a message saying it is disabled.If you enter the wrong passcode six or more times, you'll see a message that says one of the following:
  • iPad is disabled
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Hope this helps!
http://support.apple.com/kb/ht1212
Feb 05, 2014 | Apple iPhone 3G
Hi iforgot my ipad pasword help now urgent
From the Apple Support website:
If you enter the wrong passcode six or more times, you'll see a message that says iPad is disabled.
If you have previously synced your device with iTunes, you may be able to reset the passcode by restoring the device:
  • If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  • When the backup and sync is complete, restore your device.
  • When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  • Select your device in iTunes and choose the most recent backup of your device.
If you see one of following alerts, you need to erase the device:
  • "iTunes could not connect to the [device] because it is locked with a passcode. You must enter your passcode on the [device] before it can be used with iTunes."
  • "You haven't chosen to have [device] trust this computer"
iOS Forgotten passcode or device disabled after entering wrong passcode
Jan 30, 2014 | Apple Ipad 3 16gb Wi-fi Only Md328ll/a...
Disabled forgot passcode
Have to download 3rd party software from internet to disable unlock code... google it and u will find an abundance of these progs... Goodluck and post results please
Dec 30, 2013 | ifrogz iPhone3gstrb Soft Touch for iPhone...
Hi there, my son managed to get ahold of my iphone3 and due to me having a password on it he has managed to disable my iphone3, due to entering incorrect password a number of times. The password I...
Plug it into iTunes and follow the instructions on how to reset the phone. No need to take it to apple, they will do the same thing. From--Genius Bar Tech
Aug 13, 2011 | Apple iPhone Smartphone
How to disable a ipod touch
WARNING: DISABLING AN IPOD TOUCH WILL MAKE IT UNUSABLE UNLESS YOU PLUG IT BACK INTO ITUNES AND RESTORE IT.
If you want to know how to disable an iPod touch:
  1. Go to Settings> General > Passcode Lock >Turn Passcode Lock On > type in a passcode
  2. Now, hit the button at the top of your iPod.
  3. Try logging in with the WRONG passcode many times. This will disable the iPod touch.
Jan 29, 2011 | Apple iPod touch
How can i disable my ipod touch?
Do I read your question correctly: you want to disable your iPod?
Or do you want to recover it from being disabled?
For the first one, to disable your iPod:
  1. Turn ON the passcode-lock by going to Settings> General> Passcode Lock> ... and then, tap Turn Passcode On.
  2. Now, to disable it, put your iPod to sleep by pressing the POWER button once. Then wak it up. You will be asked for the passcode before you can use it.
  3. Enter an incorrect passcode several times to disable the device.
Now, if what you want is to recover your device from being disabled, all you need to do is read this tip:
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Jul 18, 2010 | Apple iPod touch
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
Apple iPhone Smartphone Logo
237 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
