Question about Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
How to change Oil
How do I change the oil when there are no plugs visible
  • Kahu Decker
    Kahu Decker Feb 20, 2012
    Unable to locate oil drain plug. how do i change the oil?
    Sergeant:
  • 316 Answers
Hello , well i use a pump,but since you don't have one the easiest way to change oil is to remove the dip stick and turn mower on side with the filler tube faceing down to drain oil,be sure and put a pan down to catch the old oil,and put fresh 20o/z of fresh 30 WT,oil in.hope this helps,any comments welcome,thank you.
Posted on Feb 20, 2012
Spark plugs covered oil
oil on the plugs is an indication of worn engine and ting problems
you can use a a hotter plug to burn off the oil or use multi point plugs to that they don.t foul from the oil
May 03, 2017 | Toyota Cars & Trucks
How do you check the oil level on a honda interceptor
I feel that this will be a perfect way for you. Check your book and see how much oil your Honda needs. Drain the oil from your bike and re tighten the drain plug. Now put in the required amount of oil .Two things will happen. you will have clean fresh oil in your bike and you will know that it is the correct amount. Oil loses its viscosity over a period of time so new oil will be good for your bike and your engine and gear box will thank you. If there are no visible leaks you will not be losing oil so you could do that every 18 months. If you don't use your bike a lot do this every 2 years.Make sure that you put new washer on your drain plug any time you change oil.
Aug 18, 2013 | 1999 Honda VFR 800
Walmart won't change oil because oil indicator light not visible, what can I do?
Go to a local Jiffylube or go to another place that usually works on cars, like a mechanic buisness.
Oct 10, 2012 | 2005 Lexus Ls 430
I'd like to do an oil change on my trailblazer 04' but i cant find the drain plug,,,,where is it? Is there a guard i have to remove?
The drain plug of the chevrolet 2004 trial blazer is located under the engine skid plate it is with the oil filter. And there is a guard to be removed. There is a trap door before it.
The skid plate door is located by the drivers side door, directly midway underneath the vehicle. You will need a flat/phillips hear screwdriver to open the trap door. Do not worry, the screws are 'loss-proff' and will not fall off the trap door plate. Once this has been removed, the oil drain plug and oil filter are now visible and accessible.
Oil change should not take you more that 15/20 minutes.
Hope this helped.
Take care and good luck
Jan 03, 2011 | 2004 Chevrolet TrailBlazer
How to do the oil change on my Jag? having problems locating the oil and filter part in the car. thanks.
The oil filter is very visible. It is located at the rear
of the engine pointing downward (not sideways) on the
passenger side (North America). The oil drain plug is also
very accessible on the lower right side of the oil pan
pointing toward the right front tire.
If you have trouble finding a replacement filter
buy the one for a Lincoln LS. Same thing. Also use 5W-30
Motor Oil. Good luck.
Mar 26, 2010 | 2005 Jaguar S-Type
05 chevy venture consuming 2 qts of oil every 500 miles. no visible smoke or oil puddles on the driveway. my van has only 90000 miles on it. the valve seals have been redone
To me that sounds pretty common with that many miles. With out changing piston rings also I wouldn't worry to much but make sure u change ur spark plugs as suggeste to avoid fouling.
Oct 02, 2009 | 2005 Chevrolet Venture
Mx5 mk2.5 slight engine oil leak.
Can you tell us more?
How many miles on the car?
Which side of the engine area? Drips after you park etc?
Oil ever low? If so how often do you ad oil?
Any visible oil on engine and bay components under hood?
likely areas for oil leaks may include depending on model and make:
Oil pan gasket seal.
Oil pressure sending unit.
Oil filter installed dry or over tightened at your last oil change.
Oil drain plug loose or plug gasket needs replacing.
Valve cover gasket needs replacing.
Crank shaft seals need replacing.
Distributor seals need replacing.
RTV gasket sealer beyond expected life and need replacing for other engine components, inspection plates or covers.
Sep 21, 2009 | 2002 Mazda Miata
97 accord oil aroud spark plug and boot
Get new cables, or try to bend the collar on the boot tighter. As far as the oil, it could have been spilled from a oil change.
Aug 20, 2009 | 1995 Honda Accord
Can't locate oil filter(2006 ) trail balzer
The oil drain plug and oil filter are under the engine skid plate. You need to remove the trap door to see. The skid plate door is located by the drivers side door, directly midway underneath the vehicle. You will need a flat or Phillips-hear srewdriver to open the trap door. Don't worry, the screws are 'loss-proof' and will not fall off the trap door plate. Once this has been removed, the oil drain plug and oil filter are now visible and accessable (how smart is that!) Typical oil change and oil filter replacement time = 15-20 mins. for a familiar shadetree. p.s. The Inline 6 (24 valve - 4.2L) takes 7 quarts of oil. Good luck!
Aug 03, 2009 | 2006 Chevrolet Trailblazer
Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
366 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
