Question about Estate TT21AKXKQ / TT21AKXKT Top Freezer Refrigerator
I have a estate refrigerator, model tt21akxk005 and water is dripping between the freezer and ice box area
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Estate TT21AKXKQ Refrigerator Leak
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 18, 2008
  • 57 Answers
SOURCE: refrigerator cooling to 59 degrees in non freezer compartment
If the fan is running you more than likely have a defrost problem.
Look at the back wall of the freezer section if it is frosted up. it's not defrosting. This keeps the air from circulating through the refrigerator section.
Posted on May 21, 2008
  • 29 Answers
SOURCE: Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Posted on Jan 29, 2009
  • 1531 Answers
SOURCE: where is the drip pan located on this refrigerator
drip pan is usually located on the bottom of the fridgfe somwhere near the compressor
Posted on Jul 24, 2010
Testimonial: "Thank you very much, How do you get to it?"
Freezer icing up
Experienced this problem with Evaporator coil icing up (coil is located inside back wall of the freezer compartment; the ice/frost was visibly blocking the series of louvers or slots along the bottom of the freezer back wall. I think the power outage caused partial melting of an already somewhat iced coil, but when the power was restored the water on the coil just froze solid. When these slots become obstructed the Refrigerator will not cool to its proper 36-40 deg.F temperature and the compressor motor runs frequently and the noise level is louder than usual. SOLUTION: fastest and safest way to Defrost this iced up coil is: (1) turn off 120V power / unplug refrigerator from the outlet; (2) remove all food to another refrigerator / freezer and take out ice cube tray & flip icemaker bail wire to its up (off) position - but leave top freezer basket in-place; (3) remove Bottom freezer basket (which should lift up and out; (4) move refrigerator away from wall - and carefully unscrew and remove white-painted, rectangular metal panel at bottom in the back....... you will see a white plastic water tray below a small fan with black plastic blades...... have a 3x5 cellulose sponge and bucket handy...... (5) open freezer door all the way and set a 21-inch box fan on the floor in the opening or area where the Bottom freezer basket was removed... put a single towel on floor under the box fan if there is significant frost on the bottom of the freezer compartment (there should not normally be any); (5) turn the fan to "Medium" speed with air flow pointing toward the freezer... you will be amazed at how much faster this works than pans of hot water or hair dryers (the latter is potentially damaging and dangerous); (6) with a flashlight you should soon see the water drip-drip-dripping from a spot at the center and bottom of the Evaporator coil - where it goes down a white tube and into the white plastic pan beneath the small fan you saw in Step #4; after awhile (maybe 20 minutes) check the white plastic tray in the back - which will be full of water (sponge it out)... continue defrosting with the 21-inch box fan... check the plastic tray again - and sponge out the excess water. A completely iced-up coil will probably fill the plastic tray three times. Eventually the water will stop dripping - which means the Evaporator coil is completely defrosted. There may be some water that gets onto the floor under the left side of the refrigerator which you will have to wipe up. Reattach the metal panel and reinstall the Bottom freezer basket and ice tray. This process takes long enough that you can clean the inside of the refrigerator while you're at it.
Jul 09, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Water dripping into the refrigerator area from the freezer
Means you have a clogged or iced drain. Remove rear panel in the freezer and pour hot boiling water into drain. Inspect to ensure it is not iced. Keep pouring hot boiling water into drain until it opens and starts to drain. Be sure to put towels on top shelves in refrigerator to catch water, then dry completely.
Feb 08, 2010 | KitchenAid Refrigerators
Iceless haier freezer is iceing in freezer area and dripping in fridge area top to bottom
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Dec 29, 2009 | Haier (492420265334) Refrigerator With Ice...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping into refrigerator from cooling area
Your defrost drain in the freezer is frozen closed.
Turn the fridge off.
Remove the rear freezer panel.
Remove the visible ice.
Use a hair dryer to thaw the drain hole in the back of the freezer in the center of the drain trough.
Mar 12, 2009 | Refrigerators
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Mar 17, 2008 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Estate TT21AKXKQ / TT21AKXKT Top Freezer Refrigerator Logo
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
