Question about Radio Communications
Trc 101 assesories
Need to know what kind of charger for inline charging, external power source conection, and external antenna adaptor.
    Genius:
  • 1,212 Answers
It is a handheld unit- it is not for fixed point use like a 12 volt mobile is or a base is, so your only real accessories are going to be Nickel Metal Hydride cells or Nickel Cadmium cells.
If you are wanting a fixed point use radio, get one better suited for the manner in which you are going to use it. The 101 is not suitable for use as a base station and should not be tried to be used as one.
But it is a unique piece of radio history though.,
Posted on Feb 25, 2012
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on amazon.com,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
I have a sterling diamond scooter. How can i use jump start to charge the battery? Is there any emergency portable charger to carry if i get stuck outside and there is no car or power.
It might be easier to carry a spare battery. I am not familiar with your unit. I do not understand how a jump start would work without an external power source.
Dec 06, 2014 | Health & Beauty
Ac adaptor crackling thru external speakers
Allan, It sounds like you have what is called a ground loop. A ground loop can occur when two pieces of equipment are connected together through a home or buildings safety ground through the same power source. For instance, your PC is connected to a power source through the AC adapter or plug, and your external powered speakers are receiving power from the same power source. The surrounding cables as well as the AC adapter(s) can act like an antenna. This will cause a low hum or crackling that would be audible through the speakers or headphones.
You may want to try plugging all components into a power strip so they are all on the same circuit. You may also want to be sure that the AC adapter cables are not not laying or running across other electrical components plugged into a different socket.
If you get the same hum through your headphones check to see if the headphones were manufactured with shielded cabling. A shielded cable is made with a wire mesh around the outside that helps reduce electrical noise. Hope this helps a little. Thanks!
Aug 31, 2012 | HP Pavilion dv6000z Notebook
Should there be a light lit up when the battery is charging?..
Yes,that the indication the a/c charger is getting power to the battery or the DVD portable player.Check ur power source?Shake the a/c wire charger adaptor around a bit might be damage some where in the wire.?Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a new a/c power adaptor charger.
Oct 21, 2010 | TruTech PVS12701 Portable DVD Player
I-mate jama 101 battery charging -internet connection
hi , i hava i-mate jama 101 , when it off because of the low power ,i can't charge it only if i charge the battery with a universal charger???
Apr 09, 2010 | i-mate Jama 101 Smartphone
I can't get it to charge
This is typically caused by one of two issues:
  1. (Most likely) The battery has failed and needs to be replaced. If the battery is older than a year and seen heavy use or been plugged in to the charger for long periods of time, this is likely the problem. Verify that the power adaptor is not bad (below) and purchase a new battery from a local retailer or online.
  2. The power adaptor is bad. Plug in your power adaptor and verify that the power LED is lit. If it is not, then it is bad and will need to be replaced or alternately, you can purchase an inexpensive external battery charger. They are available online or often from your local retailer.
A couple good sources for batteries/chargers:
http://everydaysource.com
http://www.all-battery.com/
Hope this helps.
-Tor
Dec 12, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
My Garmin Nuvi 660 device has no power.
yes it has a built in battery, the battery is not owner servicable, and that could be your problem, the battery life is around 2 years, u will need to send the unit into Garmin for an exchange GPS, to get more details the exchange program go to www.mygarmin.com, register your GPS and then select support option, u vcan also call them.
Oct 01, 2009 | Garmin Nuvi 660 GPS Receiver
External Antenna Conection
Ref ICN330. The external antenna connection is on the top side of the flip up Antenna on the unit itself. There is a small rubber plug covering this, adjacent to the Navman logo.. Ricmac
Feb 12, 2009 | Navman iCN 330 GPS Receiver
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
