Question about Toshiba Satellite A75-S209 Notebook
Soem of thekeys print numbers instead of pressing letters
Some of the keys print differently
  • Toshiba Master
  • 32,281 Answers
The Munber Lock has been selected.
Try pressing the ScrLk/NumLk key that is near the F11 key.
This will turn off the Number lock and the number lock LED.
Posted on Feb 21, 2012
2 Suggested Answers
virtualhost
  • 2185 Answers
SOURCE: when typing along the keyboard qwertyuiop, the
This means that NUM LOCK is set to on. All you have to do is to press the Fn key and then locate the NumLock key and press it. The num lock is usually also highlighted with the same color as the Fn key.
Please comment back if you still have issues. I will be glad to assist you further.
Posted on Aug 06, 2009
Above my scroll/# lock the lightbar is lit,and some letters produce #... i = 5 etc
Sounds like yo have the scroll lock or num lock turned on. If the scroll key is a colored key (the scroll lk lettering is blue) then you will have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the scroll key to turn it off. When it is turned on if you press the letter i you get the number 5. If you press the letter O you get the number 6.
Notice that the numbers on the keys that have letters are a different color than the letters (blue most times). That means you have to Press and Hold the blue FN function key at the lower left portion of the keyboard then hit the key with the same color if you want the colored representation to happen.
Some laptops will use a Square Box instead of the blue colors on the keys. In that case you have to press and hold the key a the lower left portion of the keyboard that has the square box, then hit the key you want.
Jun 03, 2012 | HP Compaq Presario C500t Notebook
Some of my keys are printing differently in my Toshiba Satellite A75 S209 Laptop
You need to turn off the Number Lock. Press the ScrLk/NumLk key it is located near the F11 key. When you turn off the number lock the NumLk LED light will also switch off and you will get letters instead of numbers.
Feb 20, 2012 | Toshiba Satellite A75-S209 Notebook
Numbers instead of letters on Aspire 1 netbook
Hi.
You have the Number Lock on. Look to the top right of the keyboard and press the key that has Num Lock printed on. That will return the keyboard to normal.
Regards.
Dec 06, 2011 | Acer Aspire One A150-1006 Notebook
Do you have a descriptions of keyboard on Windows Vista There are keys with letters and numbers with icons on them . I would like the description of the keys.
Hi.
The layout of keys can differ with different model and make laptops. The keys with letters and numbers on them are used with the Num Lock key, if you press the Num Lock key them keys will type numbers instead of letters. If you press that key again they will type letters as normal.
The keys with icons on them are used with the function (Fn) key. That means that you hold down Fn and and use the F keys to adjust things like brightness, volume, mute and Wireless radio etc.
If you are wanting a full breakdown of your laptop models keyboard then i suggest you download the user manual from HP support website. Link below.
http://www8.hp.com/us/en/support-drivers.html
Regards.
Apr 28, 2011 | HP Computers & Internet
Hye mr expert...Here i have some question about my samsung netbook n220 series. For your info...actually this problem never happen before.The problem is some of my key not working & some of my key...
The problem with your Netbook seems to be that you have turned "NUMBER LOCK" or "NUM LOCK" on. This causes some of the letter keys, e.g U,I,O,J,K,L,M to be printed as numbers 0,1,2,3,4,5,6.
To turn this off, hold down the "FN" key (near the bottom left of the keypad) and then press "F11" and then release both keys.
Please try this and post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Samsung N310-13GB Netbook
Typing numbers instead of letters
Your keyboard has "extra" keys:
* print-screen / system-request
* scroll-lock
* pause / break
* num lock
Press that "num lock" key.
For a laptop keyboard, you may have to hold down the 'FN' key,
at the same time that you press "num lock", to enable/disable this function.
Jan 02, 2010 | Gateway 7001433 Keyboard
Instead of the letter ''O'' I get the number 6 on my keyboard.
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 20, 2009 | Lenovo ThinkPad X200 Notebook
Activation of the number pad so instead of letters, numbers are appearing. still need to press the Fn key to get the desired letter.
Hi, try pressing the numlock key - this should put the number pad as standatd until it is pressed again, when it will revert to letters.
May 15, 2009 | Computers & Internet
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
My snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Nov 25, 2008 | Snom 300 IP Phone
Open Questions:
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
