Question about ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
No signal to display
Bios not signal to display
    Problem Solver:
  • 47 Answers
I really need more ifo to help here but to me it sounds like a graphics card isssue please post everything you are running
Posted on Oct 27, 2008
Emachines T3516 won't boot and displays "no signal" message
If you're using a VGA monitor, select to start up using VGA mode.
May 20, 2012 | E-Machines eMachines Desktop PC
My system is turn off and turn on no loading os and bios is not working motherboard is intel d102ggc2
Have you tried pressing F2 when you powered on the PC?
Ensure that the monitor displays the signal of PC and there is no issue with video signal. If there any issue, check with RAM.
1.If no, just press it to view the bios setting. Go to the third option below.
2.If yes and no display of bios, may be your BIOS ROM chip failed. Before that take the C-mos battery out and try again. Almost try to replace it or you must go for a new motherboard.
3.If yes and getting into bios, check for the hard disk detection. If it is detected, try again for booting. If it is detected and not booting, try to format. If it is not detected, try changing it into another SATA / IDE port. Still it is not detected, replace the hard disk.
Aug 19, 2011 | Intel D102GGC2 Motherboard
Monitor gets signal from computer but doesn't display. Monitor will display message that says no signal when unhooked from computer but will not display menu
Sound like it could be corrupted video driver. I would try holding down the F2 key to reach the system bios. Select vga for the video display if in the bios...then save and restart. If you can't get to the bios screen, try F8 and see if you can get safe mode...if so...it should allow pc to use the vga driver and thus hopefully display will work. If you get in and see windows, then you most likely ned to remove the display driver and reinstall it.
If still not working, try hooking monitor to another video port. Might need to get a conversion adapter to fit to vga port, or dvi port or whatever else you might see.
Jul 06, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Flat Panel Monitor Displays Message about No Signal, Signal out of Range, Sleep, or Power Save
You monitor can't pick the signal from the output video card, you need to remove the VGA cable and again put it back, but make sure that your PC isn't power on. After you have done this, reboot the system. You'll see that there is no more problem with the display. Sometimes this problem is caused by CPU overclocking, if the problem still persists, remove the BIOS battery and leave it outside for at least five minutes and put it back. That'll solve all the problems related to display. Good luck...
May 08, 2010 | HP Pavilion A6430F Desktop PC
Have gforce4 ti video card NO PICTURE of any kind screen says no signal detected
The GeForce4 Ti has two rear ports. 1 HDMI and 1 VGA. Try plugging into each. Video signal should be sending out of one of the ports. If neither port is sending out signal than you'll need to trick the bios.
Suggest you remove the Gforce4 Ti AGP card from the MB so you can regain video display and change the settings within the bios. Once you have display, enter the bios menu. Do you have your manual? Enter bios menu by pressing the "Delete" key every 2 seconds until the bios menu loads. Open, Integrated Peripherals, see top of page 3-11. Set Primary Graphic's Adapter to: [AGP]. Than go to the top of page 3-10. Change the AGP Aperture Size to as low as possible or to: [Disabled] "preferred".
AGP 8x Support set to: [Enabled]. Save your settings and exit the bios. The system will restart. Press and hold the power on / off button until your system shuts off. Install your GeForce4 Ti AGP video card. Double check your video card! Some NVIDIA cards need external power above what the AGP slot can provides. Some use a power connector like the floppy drive uses. Other look just like a hard disk drive power connector: 4-pin Molex. If none is found don’t worry about it.
Cheers!
Mike
Oct 22, 2009 | MSI K7N2 Delta2 Platinum Motherboard
No signal to monitor
Try go to bios setup and then try resetting bios by selecting the bios default setting. and then look up for the configuration regarding your monitor setting or try to enabled that setting.
You can manipulate the bios setting ...don't forget to save the setting.
then try rebooting the system.
melnavz
Feb 11, 2009 | HP PAVILION A6230N DESKTOP PC
9600GT No Display
Have you put another power cable to the back of the Video card. There is a slot on the back of the GT for more power. Once that is plugged in beeps will stop and you should recieve signal
Feb 09, 2009 | ASUS PCI EXPRESS 2.0 GEFORCE 9600GT 512M...
Emachines monitor has no signal
* First u can remove the display cable from cpu ( system ) .
1. Power LED coming or not .
2. Self cheak display or plain raster is comming or not. , both r ok ,
3. then u can cheak the display cable. & system.
4. 14 th pin is horizontel signal , 15 th is vertical signal , cheak the continuty the both wires.this signals is most importent for display.
Oct 20, 2008 | Computers & Internet
Mag monitor doesn't display bios post
The BIOS is sending the display information to the monitor but, when you turn your PC on, the LCD will be sleeping and it will take 1~2 seconds to wake up when receiving the display signal. The monitor is working and even if the BIOS messages aren't displayed, you can still press the correct keystrokes to get to the SETUP screen or press PAUSE in the keyboard to see what's going on in the POST.
If your LCD has a bicolor LED indicating the status (Standby/On) keep looking at it, when the LCD gets the video data, the LED turns instantly from amber to Green or blue even if the screen is still black. This way you can have an idea when the LCD gets the initial video signal and to press the keys accordingly.
Your PC will also delay the video output from the secondary video card because it's detected after the onboard card.
May 03, 2008 | Computers & Internet
ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
