Question about HP Media Center m7260n (EG642AA) PC Desktop
Doesn't always power on
First my hp media center computer NEVER powers down correctly and whenever I try to turn it on I either get stuck on the first blue screen, or it turns on and works fine for about 5 minutes then freezes and I have to use the power button to restart it, or (and this is what usually happens) when I press the power button to turn it on it just beeps continually every second or so. the lights on the keyboard don't turn on and neither does the monitor. it's gotten to a point that I never turn off my computer any more.
  • van01 Oct 28, 2008
    the beeping is continual (it never ends) it just beeps about once a second. I haven't tried removing the RAM yet. I'll try that now and let you know how it goes.
    Sergeant:
    Champion:
  • 258 Answers
The pc don't shut down correctly because of several reasons:
1. the ram had loosened.
2. the physical drive of the hard disk don't function correctly.
3.the os (operating system) might be corrupted.
but more importantly we should see every details
option1:remove the ram into its slot and clean the contact by rubbing an eraser on it and reinsert it the ram is a rectangle-shaped chip
option2:check if the hard drive is properly detected by looking at the startup screen (usually black screen)
and check the product name of the hard disk or simply check the Primary master (IDE1) if detected a hard drive
Posted on Oct 27, 2008
    Problem Solver:
  • 47 Answers
The beeps you here are bios beep they are telling whats wrong. can you count the beeps for me and give me more info on your pc
2 Suggested Answers
var-pun
  • 331 Answers
SOURCE: power on problems
the beeps mean that there is some hardware problem
if u count the number of beeps or is it continuous???????
ne way
try taking out the RAM and again placing it
the RAM might be loose
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Hp 7463 xp media center will not see hp thumb drives of 4 or 8g's. Even tried 2 different powered usb hubs. Only see error 22.
Hi turn off the computer and unplug the power cord for 2 minutes. Then replug it and start up the computer. That should solve it. If it doesn't then you have a software issue most likely a virus.
Jan 05, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
Hp pavillion media center a 1540n motherboard.....computer cpu fan runs, power supply runs, when i hold the switch it won't power-down unless i un-plug computer....no video (not even bios) does this mean...
Hello!
Try clear cmos, if the motherboard bad you must wait so long, maybe you can turn on computer, and they can work perfect, but when you turn off computer on power suply, you can´t again turn on computer.
If this so you have trouble with motherboard.
Oct 30, 2009 | HP Computers & Internet
System power won't shut down when Windows shuts down.
if same system asking about hp a1320n
drivers and bios updates
try upadating all to see if corrects
May 15, 2009 | HP Pavilion Media Center a1320n PC...
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Power on problems
ne way
Oct 27, 2008 | HP Media Center m7260n (EG642AA) PC...
Hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Jul 11, 2008 | HP Media Center m7060n PC Desktop
HP Media Center Computer
chk wether u r getting any lights on motherboard??
May 22, 2008 | HP Media Center m7250n (ED842AA) PC...
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
HP Media Center m7260n (EG642AA) PC Desktop Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
