Question about HP Media Center m7260n (EG642AA) PC Desktop
Power on problems
First my hp media center computer NEVER powers down correctly and whenever I try to turn it on I either get stuck on the first blue screen, or it turns on and works fine for about 5 minutes then freezes and I have to use the power button to restart it, or (and this is what usually happens) when I press the power button to turn it on it just beeps continually every second or so. the lights on the keyboard don't turn on and neither does the monitor. it's gotten to a point that I never turn off my computer any more.
  • 1 more comment
  • van01 Oct 28, 2008
    the beeping is continual (it never ends) it just beeps about once a
    second. I haven't tried removing the RAM yet. I'll try that now and let
    you know how it goes.
  • van01 Nov 02, 2008
    thanks that worked great!
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sounds like it may be stuck in the hibernate zone.open up the power settings, go to advanced, and uncheck
    boy, see if that helps..
    Sergeant:
    Champion:
  • 331 Answers
The beeps mean that there is some hardware problem
if u count the number of beeps or is it continuous???????
ne way
try taking out the RAM and again placing it
the RAM might be loose
Posted on Oct 27, 2008
  • Varun Kumar
    Varun Kumar Oct 28, 2008
    if ur coputer powers on sometimes the it means that ur part are OK it is just that they are not placed properly
    do post if removal of RAM and then again placing it worked or not
    pls do rate this solution
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
C:\preload\data9_04.inp cannot be recovered
You can recover the file with 3rd party data recovery software.I have succeed to recover files from external hard drive with Tenroshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost files. By the way,you can download it and scan your hard drive for free to preview whether your file can be recovered. Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Jul 31, 2011 | HP Media Center m1080n (PC099A#ABA) PC...
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
Thanks.
Mar 08, 2009 | Computers & Internet
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
HP Media Center m7260n (EG642AA) PC Desktop Logo
87 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
