Question about Samsung LN-R408D 40 in. LCD HDTV
Gray screen I have a samsung ln-r408d lcd, all i get is a gray screen, look at other post about same problem but gave no real solution, is there any ????
  • Ryan B. May 15, 2009
    Has anybody found a solution for this. I have replaced the Main board and the video interface board. Still has gray screen. It doesn't make sense that the LCD panel would be out. Please help
    Problem Solver:
  • 5 Answers
This Samsung LN-R408D TV has a small surface mounted fuse that has failed on the T-conn board (the small circuit board at the top center of the LCD panel as viewed from the rear)
The fuse is mounted slightly above the LVDS cable connector and the component marking next to the part may begin with a "F". Replacing the fuse with another fuse, or a thin wire filament, or a jumper will restore full functionality to this TV.
Posted on Sep 14, 2011
    Problem Solver:
  • 15 Answers
Try unhooking the LVDS cable from the controller board and see if it does the same thing. If so you need to replace the LCD panel.
Posted on Jan 03, 2009
How to master reset samsung LN-R408D
Unplug the TV from AC mains wall socket, and re-plug it back after 30 minutes or so. This must make a hard reset to this set.
Aug 19, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LN-R408D no display
The part labeled cp with a p on it has a black burn mark in the middle of it on mine!
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Hello..m fadhir i just bought samsung lcd tv 32" yesterday.. during initial setup/ plug & play, i suddently choose wrong language (taiwand/tahi) at the 1st step, then i cant understand anything...
hello,
To enter initial setup you can refer setup simbol with gear pict. On top menu of setup (gear) press enter again. Follow the instructions. Or you can read my post here. That the same way but for deferent problem. Good luck.
Mar 30, 2011 | Samsung LN-R408D 40 in. LCD HDTV
My Samsung LN-R408D 40 in. HDTV LCD have issue power turn off itself after being on 1 or 2 hrs. Any suggest would be great
It could be the power chord thats gone bad. I have the same television. Mine is broken as well. Would you be willing to part wit it?
Oct 13, 2010 | Samsung LN-R408D 40 in. LCD HDTV
LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Mar 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LNR408D 40 in. HDTV
Sounds like a backlight going bad or possibly the inverter. Check each backlight first for dark discoloration on the ends. If that checks out good then it's the inverter.
Mar 17, 2008 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LN-R408D 40 in. LCD HDTV Logo
637 people viewed this question
Henry  Thomas
Henry Thomas
