Question about ViewSonic E50C 15" CRT Monitor
White colour is displaying as yellow
My monitor displays white as yellow,blue as black and some colours missing,text ok sharp and clear.It's a 14 inch viewsonic E53 crt monitor.I am using it since 2003. I connect it to another pc but the problem is still there.
  • 1 more comment
  • Anonymous Jan 17, 2008
    I have the same problem but i have a samsung syncmaster 216 bw what should i do?
  • Anonymous Mar 20, 2008
    red color was not workking in my monitor
  • mdtanveer_22 Dec 02, 2008
    i have a colour lg 700e monitor but its displaying in black and white
  • 105 Answers
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Posted on Sep 04, 2006
Wiring to standard horizon eclipse GX 1 300E
It is more than likely green and yellow for one and blue and brown for the other with white being redundant ground.
May 04, 2016 | Cars & Trucks
Only BLINKING COLOURS LIKE RED WHITE BLACK
If the problem is with laptop monitor, try restarting the computer. If problem remains, try connecting your laptop to external monitor to see if problem is with laptop monitor or with display adapter.
If picture also like this with external monitor and with laptops own monitor after reboot, possible HW issue can be expected.
Mar 06, 2014 | HP Computers & Internet
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
White colour displaying as blue, and red colour displaying as black
It's simple i had the same problem the solution is u go to the settings menu in the monitor and reset the options and settings.
Sep 29, 2010 | ViewSonic E50C 15" CRT Monitor
15''lcd monitor cable problem.
Hi, this may not be solution for what you ask but rong signal can or mayset u monitor on flames it hapined to me, why? hold on to old cable whan you can go and get new one, if you say you cant find, then get a moltetester chack the each ends pin to pin for contanuity. good luck
Jun 22, 2009 | Computers & Internet
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Yellow dispkay
the display turns to yellow when the blue colour is missed form cable. check the vga cable or may be it's from inside monitor. from the vga card. check the cable first then call or mail....
Feb 22, 2008 | Microtek C893 18.1" Flat Panel LCD Monitor
ViewSonic E50C 15" CRT Monitor Logo
640 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
