Question about Emerson Televison & Video
My emerson lc320em1f tv will not show a picture here is what it does with multiple times of hitting the power button....please help...thank you
If i unplug the tv plug it in the red standby stays on solid then you hit power button and green power blinks 5 times goes off and red standby stays on solid....then i hit power again the power light blinks 5 times again and red standby stays on ...then hit power again and red standby goes off power blinks 5 times and then both power and standby lights stay on solid all this and no picture at all
  • Mtend Nov 27, 2012
    Emerson 19' tv. You can hear the sound but the picture if black and has lines running down the screen but that is all you can see. What could it be? Is this something that can be fixed or should I buy a new one?
bestdarngood
  • 3037 Answers
SOURCE: telivision dont want to power up.
You are experiencing the Mitsubishi Green Blinking Light of Death which is fixable.
All you need to do is replace the four 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors) which are inadequate for this tv. These capacitors are apparently undersized, in that they will eventually fail (usually after about 3 years) if and inevitably when there are voltage fluctuations in the circuit above 16 volts. It is then recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur.
If you are good with soldering and know how to work with electronics then this will be an easy fix otherwise I suggest getting someone to replace the capacitors that knows how to deal with them without getting an electrical shock. You can get the capacitors at any electronics store such as Radio Shack.
Good luck and please let me know if you have any further questions.
thanks
Posted on May 01, 2008
SOURCE: Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Posted on Jul 15, 2008
Senco
  • 51 Answers
SOURCE: I have an Emerson TV 32
You will need Power-Inverter board.
I do have them in stock!
Please be free to contact me at plasmatech@gmail.com
Posted on Dec 08, 2008
SOURCE: No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Posted on Jan 28, 2009
SOURCE: Blinking red standby light flashes
blinkig red stand by stay on when powr button hit
Posted on Feb 01, 2009
The screen shows a picture but has the color lines going through the screen. FYI, something hit the screen but it is not broken.
maybe the screen is not broken but the circuitry behind it is
take it in for a repair quote
Jun 22, 2016 | Emerson Lc320em1f TV
Model LC320EM1F. Why doesn't t turn on?
Model LC320EM1F
  • Al, Power supply board instructions. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Emerson 32 TV LC320EM1F HOWTO replace power supply part 1
Mar 25, 2016 | Emerson Televison & Video
My emerson lcd 39" tv is blinking red constantly, before and after I hit power button, no picture, no sound, no nothing, replaced power board. No change. Suggestions?
Best possible thing at this point is the mainboard. The blinking shows you have have some power, although that only takes low voltage. More times than not, a power board problem usually shows itself as a completely dead unit. The board should be fairly inexpensive, but always weigh the cost of getting a new TV. Also, if you buy the board from an online distributor that takes returns, you can get most of your money back if it turns out to be something related to the panel.
Aug 15, 2015 | Emerson Televison & Video
How can I get a full picture on my TV?
Buy a programable remote with a format button on..after programming for your tv..use the format button to change the screen size
Aug 15, 2014 | Emerson Televison & Video
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
32'' emerson tv says digital telivision then nothing
press power screen reads digital television then the power light and stand by light turn on then screen goes black
Nov 26, 2012 | Emerson Lc320em1f TV
No picture on emerson loc320emif
Show a torch light on the screen from a safe distance, when program runs. If you can see the picture, the problem is with the backlight and might require the attention of a qualified service technician.
Aug 01, 2012 | Emerson Lc320em1f TV
I have emerson lc320em1f tv but no remote, need help changing ratio
For my Comcast, One for All remote the code was 0171 for my Emerson 32" LC320EM1F TV from Walmart.
Sep 22, 2011 | Emerson LC320EM8 32 in. LCD TV
Televison & Video Logo
183 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
