Question about Garden
Where can I order a spool housing for a remington electric trimmer/edger model ST3812B?
I actually only need the retaining ring that slides over the spool of line, but I haven't found that anywhere. So the spool housing is the best next bet. Sure would like to use my trimmer this spring.
  • Karen Hawkins Feb 21, 2012
    This spool housing is for a Desa Remington trimmer edger (Model #ST3812B trimmer/edger. I only need the part, not the whole trimmer/edger.
  • Amy Devereux Sep 02, 2013
    Were you able to find the part? I am looking for the bump spool and the response to your posting did not have the part.
    Sergeant:
  • 316 Answers
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
  • 12 Answers
SOURCE: corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Posted on Aug 18, 2008
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
  • 4 Answers
SOURCE: spool removal st4000 trimmer edger black&decker
Push the tabs tother and pull the cover off, the spool then just slides off http://www.blackanddecker.com/Productimages/PC_Graphics/PHOTOS/BDK/OUTDOOR_PRODUCTS/TOOLS/LARGE/4/ST4500_A4.jpg
Call ALM Manufacturing 01423 797208 for stockists of a new spool
Posted on Jun 01, 2009
#1 Taper
  • 1040 Answers
SOURCE: how to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jun 28, 2009
How to remove spool on craftman 25cc gas trimmer
Unscrew the bump knob. Pull out the line spool. Remove the retaining push washer from the drive shaft. The spool housing will now pull off the shaft.
Sep 26, 2014 | Garden
Front differential diagram
Looks like you have your answer. most toyota's I have dealt with were full floaters, no lock ring needed. good luck
Mar 31, 2014 | 1993 Toyota Pickup
How to replace the string in grasshog xp electric trimmer
Ran into the same problem recently and discovered that one solution was to use a standard adjustable wrench and grasp the center, leveraging off the spool cover. If you look closely at the spool it is tapered so the very top of the hole in it is actually slightly smaller that the spool cover point it slides over letting it seal pretty tight over time.
May 21, 2013 | Black & Decker Black and Decker & Grass...
Need to replace retainer ring on cord for 8 oz kettle on gay nineties popcorn machine model 2131.
That part won't be found online anywhere. Gold Medal is gmpopcorn.com but their parts available online is slim.
The cord for that kettle has 4 different designs possible, only one has a retaining ring.
A small plastic ring on the plug, usually light grey but maybe black. It was only used for a couple of years in the mid-late 80's. Part #47978 coupling ring, small. Pretty rare part actually, I have them in stock. Contact me at kernelpops@yahoo.com.
If you can send a photo of the part you are looking for, (or where it is missing from) it will be easier to get the correct part.
Tim Eischens
Kernel Concession Supply
Mar 25, 2013 | Kitchen Appliances - Others
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Can i replace the power steering reservoir in my 1993 grand cherokee?
Hi Riley:
Nice car, I have the same '93 5.2L V8, according with the Jeep Repair Manual for 1993 at 1998, check this procedure to RESERVOIR REPLACEMENT - REMOVAL
(1) Remove power steering pump. Refer to Pump Replacement in this section.
(2) Clean exterior of pump with solvent.
(3) Clamp the pump body in a soft jaw vice.
(4) Pry up tab and slide the retaining clip off (Fig. 7).
(5) Remove fluid reservoir from pump body. Remove and discard O-ring seal (Fig. 8).
INSTALLATION
(1) Lubricate new O-ring Seal with Mopar Power Steering Fluid or equivalent.
(2) Install O-ring seal in housing.
(3) Install reservoir onto housing.
(4) Slide and tap in reservoir retainer clips until tab locks to housing.
(5) Install power steering pump. Refer to Pump Replacement in this section.
If you need other additional details or some specific section from the Repair Manual, feel free to contact us in the previous links.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 25, 2011 | 1993 Jeep Grand Cherokee
I have a 27cc Craftsman 2-cycle weed trimmer, dual line, bump advance. I haven't got the manual and don't know how to get the bottom off to replace the line. I have pushed and twisted, but it...
Hi there, I just came across your post while looking for my own answers.
If you haven't yet found the answer, try this: Hold the spool immobile and twist the knob counter-clockwise. If your machine is like mine the knob will simply twist off (it is on a threaded shank that goes into the reel cover.)
If you have the model number, the manual is probably available on ManageMyLife.com at http://www.managemylife.com/mmh/owner_manuals
May 18, 2011 | Garden
Need step by step inst. to replace fuel pressure reg.
  1. First, you will need to depressurize your fuel system. Remove the Fuel Pump Relay, start the vehicle and run until it shuts off, should only take a few seconds.
  2. The Fuel Pressure Regulator is held in place on the Fuel Rail using a Retaining Ring, or Snap Ring.
  3. You will need to remove the Vacuum Hose connected to the Fuel Pressure Regulator before you remove the retaining ring.
  4. You need a pair of Snap Ring Pliers to remove this retaining ring.
  5. Once the retaining ring is removed, slide the old Fuel Pressure Regulator out, and install the new one. Lubricate the O rings on the new part and the fuel line before assembly.
  6. After reinserting the Snap Ring, ensure that it is snapped in place completely.
  7. Reinstall the Vacuum hose and reconnect your Fuel Pump Relay. Turn the Ignition to On, and check for leaks around the Fuel Pressure Regulator.
  8. If no leaks are found, proceed to start the vehicle.
Mar 15, 2011 | 1998 GMC Jimmy
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Garden Logo
583 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
