Question about Harman Kardon Audio Players & Recorders
The volume button don't work!
The volume up button stop working, now the sound is really low and i can't get it louder. Help please!
  • Anonymous Mar 23, 2014
    I've checked the button with multitester it seem ok..but the sound isnt increasing when I push vol up..please help
  • 27,725 Answers
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Posted on Feb 21, 2012
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: hi the sound in my
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Posted on Sep 15, 2011
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
Volume up button won't work
If you have speaker in the lower right in the tasbar, click on the speaker icon and slide it up to increase volume.
Jul 12, 2012 | Lenovo ThinkPad R60 Notebook
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
My Marshal Amp MG50DFX sound is very soft even tho the volume is on max. when I switch on the gains circuit and turn up the gains control there is louder sound, but a humming niose also, what can the...
First of all please check your cables because this kind of problems mainly arise due to cable errors.Second solution is check your input.For an example try a another input from a DVD player or etc.Third solution is ,you have to check your amp's mic volumes,please reduce your mic volume fully.Check you equalizer too,Please check and inform me if it doesn't work
Sep 15, 2011 | Audio Players & Recorders
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
I've had the Tonebone Plexitube since January of this year, but have only played through it a couple of times. I recently took it out to really experiment with it and get to know the pedal. Right away...
It sounds like somehow the pre-gain is very high while the volume or post-gain is very low. Try turning the volume high on the effects unit and the gain low, and don't have the amp volume too low either.
May 18, 2011 | Radial Tonebone Plexitube Effects Guitar
Nokia BH-103 low volume.
bh 103 is fail product don't advie to other i suffer lot because i purchsed before 12 houres volue very low it is like 100 rs local ear phone & current it stop working with in 4 minits playback nokia now start bad production & try to foll to all customer
Jan 19, 2010 | Motorola Mobility H710 Bluetooth Headset
GoGear 4GB SA3345
i have the same problem but am taking it further check out this link http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
Jul 02, 2008 | Philips GoGear Flash MP3 Player
71 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
