Question about Polaroid FCM-0700A 7 in. Portable Television
Sound works, picture is very dark
Hi, more tv used to work, but now only volume does. I can see the picture in the back ground if i shine a light on the screen.
    President:
  • 3,130 Answers
You have to be specific when asking a question please. as you dont mention its a flodable LCD screen TV as I had to look it up. your problem is in the backlite circuit. if your a tech, you should have no problem finding this fault but could be a little trick if your not as your going to need to know how a back light circuit works, the parts in the circuit and know how to use a multimeter. Good Luck
Posted on Aug 25, 2006
My samsung 62" tv has no picture/have sound
Darken the room. Very dark. Turn tv on. Press menu button. Get flashlight and shine at screen. If you can make out the menu barely. It's the back light gone. Is it plasma or lcd.
Jan 01, 2018 | Samsung Televison & Video
When I turn on my Sharp TV the picture comes on for a second then goes black. The sound is working but the picture stays black.
hi quick test, in a dark room shine a flashlight on the screen, if you a can see an image, bring the menu up if you can see it the led or leds in panel may blown, thanks
shaun
Feb 15, 2017 | Televison & Video
How do you get rid of the half black screen on westinghouse 40 inch led flat screen tv.
it sounds as though some of your LED back lights are not running, you can verify this by shining a flashlight onto the dark area of the screen (in a darkend room)to see if there is a picture there but not back lit. If this seems to be the case it will most likely be the back light inverter/driver board, on some sets this function is carried out on the power supply board, have a look at shopjimmy for tech info on your brand:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 06, 2016 | Westinghouse Televison & Video
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
The red light turns on but no picture comes on
Get real close to screen and maybe use a flash light to shine on the screen and see if you can see the picture still, it will be dark and almost not visible but you should notice something move. If your screen has picture then you most likely have a back light problem. Most common problems are bad inverters, or the inverter controller card. possibly a bad power supply but most likely inverters, test each circuit, replace as needed.
Sep 17, 2012 | LG Televison & Video
I have a proview lcd screen and it palys the tv shows in back ground but it's a dark screen like dark blue no picture. Volume and everything working but just no picture. What can i do.
Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
Jul 25, 2012 | Proview PA-37JK1A 37 in. LCD Television
I turn tv on volume works but no picture?
The Inverter is bad - this is used to power the back-light of the screen. With a flashlight, shine the light on the screen to see if you can detect images. If you do, then that confirms a bad Inverter or the back-light bulb itself bad.
Nov 24, 2010 | Vizio L32 32 in. LCD HDTV
LCD TV has sound but no picture.
Shine a small bright light at the screen when on and see if you can see a faint picture in the dark screen. If you can then your backlighting is not functioning due to ccfl (inverter), power supply, or back light lamps.
Mar 27, 2009 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Television has audio but no video
Hello blondemommy0,
This sounds like your inverter or back-light has gone out. What you can do to test this is to turn the TV on and then turn off all of the lights until the room is dark. Then shine a flashlight at an angle on the screen and see if you can see a picture. If you can the back-light and or inverter has malfunctioned. If this is the case, then I would suggest that you have a qualified TV technician fix this problem, but first ask for a estimate because the inverters and back-lights are sometimes part of the screen and is it is you might as well buy a new TV.
I hope this helps,
Thank you,
Shuttle83
Electron-Age Technologies LLC
www.electron-age-technologies-llc.com
Nov 15, 2008 | Sanyo DP32746 32 in. LCD Television
Polaroid FCM-0700A 7 in. Portable Television Logo
128 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
