SoundDock Connection Hi - Did you get the answer for the SoundDock connection? on Which pin is 18v and which is -18v? Thanks
  • 2,071 Answers
Hey dskum i have the voltages connection,do you have an email add, I have also problem in Pre-amp.section the IC is blown,so i wanted to know the number of that IC.The powersupply voltages is normal i have negative and positive 18 only the sound is gone because of blown IC.My e-mail add is
Posted on Jun 12, 2009
Ipod classic 80GB makes a horrible popping noise with sounddock II
Sounds like there might be a loose connection between your iPod and the dock. Firstly make sure there is no dust or grit inside the female 30 pin of the iPod. Also make sure that there is no grit or dust around the male end on the dock. If there is grit or dust (or even if there isn't, some compressed air (you can buy this in a can) will help to clean out the connection. Also make sure that when you dock the iPod, it is seated on the dock properly. You should be able to see if it isn't seating properly. If this doesn't fix it and you are near an apple store, I would recommend taking the problem to them where they will be able to make sure that the iPod isn't causing the problem.
Nov 30, 2013 | Bose SoundDock Digital Music System for...
Bose SoundDock Power Supply Pin-outs so I can test one
Hi, The pinouts are as labelled below. The original Bose supply allows for 1A max current, so I would prevent your power supply from going above that.
May 20, 2013 | Bose SoundDock digital music system...
My Bose Sounddock stopped playing. I believe
mostly the flatcable from the dockingplug to the ampifier has a bad connection ,try to connect it again or resolder the contacts
Apr 19, 2010 | Bose SoundDock Portable Digital Music...
I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
Aug 24, 2009 | Bose SoundDock digital music system...
Bose Docking Station incompatibility with IPOD Touch
You need to reset your ipod. You can go online to find out how to do this. I had to do it with mine and then it worked perfectly.
Aug 08, 2009 | Bose SoundDock digital music system...
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
I have a lifestyle system with surround sound at central location and two remote rooms connected through two additional amplifiers. The central location works perfectly well. Recently, I started getting...
Probably the connection in the main room to the wirless transmitter. The problem is definitely between the media centre and the wireless sender as it is not effecting the main zone and is effecting both second zones. Multi pin connections can bend very easily if pushing the connection further in does not solve it you may need to replace the pins. why not call Bose tech?
Feb 19, 2009 | Bose SoundDock Digital Music System for...
Sounddock power supply
Hi. To answer your question: The center line of the coaxial cable is ground. The inner metal side of the outer ring is the +18V. The outer metal side of the outer ring is the -18V. I will try to draw it below:
Sep 02, 2008 | Sony ICF-C1IP (Black) Docking Station
54 people viewed this question
