How do I find out my wep key
My hard drive died and I do not know my wep key. All of my passwords were on the dead hard drive.One other computer in the house is on the wireless network with the wep key but mine is not. How do I get the wep key for my computer? Do I have to do something special since I have a new hard drive. My computer can pick up other connections but my wireless connection called "animator" I cannot access.
Thanks for helping.
    Problem Solver:
  • 11 Answers
Looks like you will have to login to the router from the other computer to find the key.
Usually, the address to the router admin screens is one of the following:
192.168.0.1 Linksys
192.168.1.1 NetGear
192.168.10.100 Motorola
Generally 192.168.1.1 will work for most.
Default Login:
Login = admin
Password = password (default - if this doesn't work, then you will need to find it or initialize the router)
Go to the WEP security Screen
NetGear EXAMPLE:
Security Encryption (WEP)
Authentication Type *Automatic*
Encryption Strength *64bit* (64 bit is sufficient - the network overhead is less than 128 bit)
Security Encryption (WEP) Key (The active key below is marked with *)
Passphrase *Blank*
Key 1 abcdabcdab (64 bit examples = 10 hex digits 128 bit will be longer string)
Key 2 dcbadcbadc
Key 3 123456789a
Key 4 *Blank*
Click logout when finished
LinkSys Example:
Wireless Network Menu
Wireless Network Mode Mixed
Wireless Network Name (SSID) MyWireless
Wireless Channel 7 - 2.442 GHZ
Wireless SSID Broadcast Enable
Wireless Security
Security Mode WEP
Default Transmit Key 1 (This is the active key)
WEP Encryption 64 bits (or 128 bits)
Passphrase
Key 1 abcdabcdab
Key 2 dcbadcbadc
Key 3 123456789a
Key 4
There is no logout for the LinkSys. Just disconnect
Posted on Oct 27, 2008
  • 16 Answers
Here's an easier method that doesn't entail having to log in to your router. Provided you've got another Windows computer that's already connected to your wireless network, this free program will allow to to retrieve and view the network's WEP key:
http://www.nirsoft.net/utils/wireless_key.html
I hope this helps.
JohnB
Posted on Mar 25, 2009
  • 23 Answers
There's a very easy way, which will prevent all such problems, in case you forgot the router password because usually by default it's:
Suppose IP is: 192.168.1.1 then
Username is : admin
Password is : admin
In case you are failing to control your router, there's a small reset press from the back of the router machine, you have to press it with a very thin pin for 5 seconds, and then go again to the router:
192.168.1.1
user: admin
pass: admin
Go to quick start and make the configuration. In case the configuration is belong an adsl, you have to contact the free line of customer help line for the technical section in order to get the configuration of your adsl and to make your InterNet working.
Try such option and inform me if you need anything
Posted on Aug 08, 2009
How do i find wep key
Connect your router to computer with lan cable then you can access it with default link http://192.168.1.1 then type user as "admin" and password as "admin" or blank or "password" then you can see settings of router. Click on wireless then wireless security WEP key note down the code it is your password to connect wireless. Let me know if you need further assistance. Thanks for using FixYa.
Apr 06, 2011 | D-Link DIR-615 Wireless Router
Where do I look on my "main" computer (hard wired
Hi dkusner,
Welcome to Fixya. If you need your Wep/Wpa Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Feb 10, 2011 | NetGear WGR614 Wireless Router
Hello i just baught a playstion3 how do i reset my router cause i forgot the password for the wpa key
chevyjosh815
If you forgot WEP key for your router you just need to log into the router and look up the key. If you do not know the Admin password for your router then you will have to do a hard reset of the router.
The links below are examples of what steps you woudl need to go through to look up the WEP info on your router.
How to setup WEP on a Linksys Wireless-G Broadband Router
How to setup WEP on a Belkin N1 Wireless Router
How to setup WEP on an SMCD3GN Wireless Cable Modem Gateway
If you have any questions or problems let me know the make and model of your router so I can better help you.
Issken
http://www.fixya.com/users/issken
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
WEP KEY
WPA KEY
When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
First check your network option also.
Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
WPA is same as WEP
(WEP)
You need to sign in your router first.
1.open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1)
http://192.168.0.1/
2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
Now you can see your D-LINK webpage where you find your wep key.
Clik setup then wireless setting
Now you see on this page
1. Wireless Security mode then drop-down-menu Set Enable WEP
2. Authentication - Choose Shared Key.
3. WEP Encryption - 64 Bit.
4. Key Type - HEX
5. Default WEP Key - WEP Key 1
6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
You should write your password in paper first then you will have to add this key into your pc. network.
You can not connect internet because you have to put these Key(password) into your pc first.
Go to your network connection in your pc Choose your network
Or
You see two computer( internet icon) on the desktop
Right click then connect to network then you see so many network & your network ( Which you create).
Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
WPA
1. Wireless Security mode then drop-down-menu - EnableWPA
2. Clipher type -TKIP
3. Passpharse - create own password here( don't put any personal info there)
Save setting
Device restart.
Now check Network status. Its working now.
Follow youtube video
Jun 10, 2010 | Computers & Internet
Need to get wep key for new ps3 250 gig hard drive
The wep key is for the wireless router. It is the password. If you enabled wep security on your wireless router and created a password, it is the password you created. If this is someone else's wireless network you will not know what their password is.
Mar 14, 2010 | Sony Playstation 3 (PS3) Console
Trying to coonect to ndsi butcant find wep key
If you don't know the key, and you don't have a computer that has the ability to display the password for the wireless for you, the only other way you can retrieve the password is by plugging in directly to the 2wire, logging into it, and either getting the password as it is listed by the 2wire, or resetting the password to something new.
May 29, 2009 | 2wire Computers & Internet
I am needing the key or WEP to re-connect to wireless
If it was not setup with a WEP key then try "admin" that is the password for Linksys when not set up. The purpose of the WEP key is to install a password to type in before anyone can use your network. So if "admin" does not work then you have to ask the person who set up the Wireless Network what the WEP key is.
Jan 02, 2009 | Computers & Internet
How to load new ssd for eee pc
By SSD I assume you are refering to a Solid State Drive to replace your existing hard drive. If this is the case you need to install the drive and then boot off the CD that came with your computer and reinstall the operating system. Note that all you old info will still be on the original hard drive but you can still access it by purchasing a 2.5 inch USB hard drive enclosure. When you plug it into a USB port it will be detected as a second hard drive.
Jan 02, 2009 | ASUS Eee 900 Notebook
Password protect
You can find the complete manual here.
Go to page 62 and read from there.
You want to change form "Open System" to "Shared Key"
You have to enable WEP and use 256-bit encryption, which gives you a key length of 29 characters. Choose them as randomly as possible, but copy them to a text document. This way you can copy them to a USB drive and deploy it to your computers without re-typing it over and over again.
Just a note: WEP encryption is fairly easy to crack if you know what you're doing. Nevertheless it is better than nothing, but it should not give you a false impression of security. Just google "crack WEP" and you get over a million results...
Dec 27, 2008 | Westell Wirespeed VersaLink...
Password
In order for you to find your routers address, click START, RUN, type CMD followed by RETURN or ENTER, and type IPCONFIG/ALL followed by RETURN or ENTER. Look for DEFAULT GATEWAY. Put that address in your browser to access it.
Jul 12, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
2,426 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
