Question about Tools & Hardware - Others
Where can I find a driver blade guide and driver blade seal for a Hilti RN312 framing nail gun?
I have located a "bumper/piston stop" and an o-ring rebuild kit, but I need the driver blade guide and the driver blade seal. I contacted Hilti and they informed me that the RN312 was discontinued in 1993 and that I may be able to find parts from a past distributor???
  • Jaime Mercado Jul 26, 2012
    where did you find the bumper/piston stop for the hilti rn 312. I need one
  • 425 Answers
That was basically the same tool (with a few small differences) as the Spotnails MNS5. On the Spotnails version it uses a round, thick piece of plastic with a D shaped hole for the driver guide. There was no driver blade seal. If that is what you need I may have a few left in stock. We are Twin City Supply in Loves Park, Illinois.
Posted on Mar 06, 2012
3 Suggested Answers
  • 142 Answers
SOURCE: Gun stopped driving nails, air escapes from top,
has the gun been cleaned and oiled, i think not.
take the head bolts out of the top of the gun. make sure you pay attention to how everything comes out so you can put it back together.
shake the gun upside down so that the piston comes out. wipe everything down with any petroleum based cleaning solvent to remove all the gunk and reassemble.
pour about 10 dropsof oil down the air input, let it sit there about 5 mins and hook up the air and it should work
Posted on Sep 23, 2009
  • 1383 Answers
SOURCE: My husband has a Hilti RN312 nail gun and can not
The company below sells a full line of nails for your gun. The rn312 uses 17 degree nails and can be ordered from www.spotnails.com. Good luck with your nailing projects.
Posted on Aug 11, 2010
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
Parts for Bostitch N80
Easy test, Remove the nails and remove the trigger retainer pin and trigger to expose the trigger valve (tva6 valve). With air connected and nails removed, quickly depress the trigger firing pin all the way in. Gun should fire (if gun fires, adjust safety foot to make better contact with tva6), if no joy air is leaking past orings in the head valve or head gasket vent hole and/or trigger valve. Remove head and check gasket around vent hold (small hole in the head gasket). If the gasket good remove head valve and examine surface where orings make contact for fine scratches. If scratched or worn, orings are not sealing. To check if orings are leaking, apply lots of white grease to orings in the head valve, replace the head and test fire. If the gun fires, sand contact areas with fine sandpaper and or use oversize orings or wind teflon tape under the external orings. The metal ring or washer that you are wondering about is sometimes used to space up the bumper to control depth of nail. Other nailers use a metal fitting under the bumper to help guide the driver and to seal the lower chamber helping to prevent too much air leaking past the driver. If too much air leaks past the driver, guide, the piston may not return to top. Good luck
Nov 17, 2012 | Air Tools & Compressors
Need nails for RN312 Framing Gun
Special order only and they are expensive. We used to sell the Spotnails MNS5 which was the same tool as the Hilti. All we have left are some 8 penny nails. We have inquired about more as Spotnails does not produce them anymore and the cost wasn't worth it. You will be better off to buy a newer gun that shoots a more common nail.
Jul 31, 2012 | Air Tools & Compressors
Why does my roofing nail gun jamming, it would fire one nail and the hammer will remain out, so i toke a screw driver and push the hammer back in, and it still did the same thing
Simple test for piston jam. With nails removed and latch open, point nose of gun up then down. If the driver slides up and down in the cylinder as you move the gun, replace the piston oring (test gun for proper operation). If the piston stays in the upper most position as you move gun (push driver to top position), check lower bumper and bottom seal under the bumper (sheet). Replace as needed. If the lower parts are in good condition (good piston oring, lower bumper and sheet) , replace the 3 orings on the feeder piston. Good luck
Dec 03, 2011 | Hitachi NV45AB2S Coil Roofing Nailer
Nail gun shoots 1st nail fine then second is a blank. The gun is clean, there is no jam, they are the right nails. PSI is at 100. Person using gun has used this gun and others for a very long time. ...
Miss fire usually occurs when piston/driver is bent, piston oring worn, lower bumper cracked or missing pieces or upper bumper is cracked. Easy to check. Remove head and pull piston. If bent try to adjust, but be careful, blade breaks easily. Piston should fit snugly in cylinder, if loose, replace piston oring. If oring/plastic ring ok examine lower bumper for cracks and replace as needed. If lower bumper ok, pull out headvalve and examine upper bumper for cracks. If upper bumper ok, pull cylinder and look for loose check band around cylinder. Check band is black rubber and should be placed around cylinder fitting snuggly covering series of holes. Replace parts as needed and lube with silicone paste sold at Lowes in the plumbing department (or white grease). Good luck
Jan 11, 2011 | Porter Cable FactoryReconditioned DA250BR...
I have a SCN40R gun that doesn't advance the nails in the coil part. What could be the problem. The part that is suppose to advance the next nail doesn't move.
The feed pawl is moved by a piston that extends from a cylinder on the lower side of the guide body. There are a couple seals inside the cylinder that if damaged will not hold enough air to activate the piston and advance the next nail. The two seals are Senco part number LB0828 & LB0845. Better yet get a Senco YK0369 repair kit and replace all of your o-rings, you'll have a like new gun for around $60.
Jan 06, 2011 | Senco Air Tools & Compressors
My framing nailgun hammer will not return
Driver not returning is usually caused by bent driver, worn lower bumper, loose piston oring and/or loose or broken check seal. Remove nails from magazine and push driver to top position; lightly tap nose of gun against rubber mat or soft wood. Driver should remain at top. If driver slides down, replace piston oring. If driver stays up remove head and pull out cylinder. Examine driver for bend, check lower bumper for missing pieces and look for check seal inplace around outside of cylinder. The check seal covers a row of holes in cylinder and could be oring or rubber band. It should fit snuggly around cylinder. Replace parts as needed. If all parts look good, examine upper bumper for cracks or missing pieces. It is located in the headvalve and is usually made of vinyl. When installing piston, check that it does not fit too tightly in cylinder. You should be able to push it down cylinder rather easily and stay in positon without dropping under its own weight. Lube all orings with silicone paste (sold at lowes in the plumbing or swimming pool departments). Good holidays
Nov 28, 2010 | Porta Nails Clipped Head 34 Degree Framing...
I have Bostitch RN45 coil nailer. It sometimes does not feed nails. When I open the magazine the driver blade has not retracted. Gun does not leak, o-rings in drive section look to be in good shape and...
Causes of piston not retracting are as follows. Cracked /worn bumper, if cracked air will leak between piston and bumper. Try test, remove nails and dry fire gun against rubber or soft wood; depress trigger push gun against wood/rubber and hold in this position. Piston should stay down and no air should leak past nose. Worn piston oring, piston should not slide down cylinder under its own weight. Loose or missing check seal, remove cylinder and look for black rubber band around series of holes. Band should be in place and fit snuggly. Good luck
Oct 20, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
My driver doesn't come back far enough to pick up the next nail
Many causes for this problem. Some things to check. Push the driver up by hand to see if it moves easily /hard. If hard, check for bent driver or dry cylinder. If it moves easily, check piston oring too worn and /or air could be leaking down past the bumper area. Most guns have very close fitting bumper or a seal below bumper. If too much air leaks down past bumper driver will not return fully. Check seal could be loose or broken. Remove cylinder and look for check seal covering a row of holes on outer/mid to lower part of cylinder. could be a band or oring and should fit rather tight. If ok only other parts to check are the headvalve and piston stop. Piston stop should not have cracks or missing pieces (piston stop slows/stops piston when it returns to top). Head valve should be well lubed. Good luck
Oct 03, 2010 | Tools & Hardware - Others
My husband has a Hilti RN312 nail gun and can not find nails for it, do you have an idea where we could find some?
Aug 05, 2010 | Hilti Tools & Hardware - Others
Tools & Hardware - Others Logo
135 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
