Question about Dewalt Air Tools & Compressors
Nailer wont shoot nails d51238
Model d51238
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 1388 Answers
SOURCE: nail would not shoot out
The problem that you describe is caused when the driver is not returning all the way back up to the top of the cylinder not allowing the nails to enter into position . You may have one of several problems including worn piston oring, bent driver, worn check valve, worn lower bumper, or low air pressure. Simple test is to manually push the driver blade back to top using a thin piece of metal that fits into bottom of gun. Be sure to disconnect from air supply when doing this. Good Luck
Posted on Jan 08, 2009
comax
  • 154 Answers
SOURCE: Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
Posted on May 28, 2009
  • 1388 Answers
SOURCE: DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Posted on Jun 18, 2009
  • 8 Answers
SOURCE: my mastercraft electric brad nailer stapler wont
Look for a jam in the gun.Sounds like a brad is "hung up" in it, probably right at point where it feeds into the mouth of the firing point. Be sure you unplug it before you do this.
Posted on Jan 15, 2010
I have a prime air roofing nailer...it will shoot one nail wont shoot any more til i open an push nails into position
It sounds like the auto feed is jammed. It just might be some dirt holding the slide from advancing or it could be a broken feed spring.
Aug 06, 2016 | Air Tools & Compressors
Dewalt D51238 not firing when trigger pulled but air does come out?
Remove the head and lube the headvalve with white grease. If gun still does not fire and makes air noise at the trigger valve then orings within the trigger valve are worn. Replace the trigger valve or if you have a source for small orings, just replace the two orings on the metal stem (2mm x 1.5mm). Dewalt uses vinyl orings on the stem that fail. Replace with buna. Good luck
Oct 13, 2014 | Air Tools & Compressors
My roofing nailer just started blowing air and wont shoot any nails
Most often this is a jammed nail or head of a nail jamming the driver. Inspect to see if there is a jam and if you can push the piston back up freely. If there is no jam and the piston moves up and down I would install a service kit - one of the O-rings has failed.
If you let me know the model I can get you the part number you will need.
Good luck
Sep 26, 2014 | Air Tools & Compressors
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
F28 ww framinf nailers. 4 relatively new
It sounds like you are using the wring nails. check the recommended nails and the degree of the strips. there is a large variety of degree's available if it is a Bostitch usually 28* is what your looking for. next the gauge of nails need to match and then whether or not they are paper collated or wire. that will cause problems like that all day. hope this helps
Dec 28, 2009 | Stanley Bostitch F21PL Nailer
When you bump nailer it wont kick out nails
new safeties on nailers have to push set safety than pull trigger no more just hold trigger and bump shoot nails
Oct 06, 2009 | Dewalt Air Tools & Compressors
Exterior Galv. 6d cooler 2x .113 21 degree
This nailers are very inclusive , i have experience issues when i try other nails brands, and when i put DeWalt nails they work just fine. keep in mind that most nailers have a safety that when a couple of nails are in the magazine it wont shoot,
Apr 02, 2009 | Dewalt D51844 Framing Nailer
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Air Tools & Compressors Logo
246 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
