Question about Philips DVP3345V/17 DVD Player/VCR
Not staying powered on
My grandparents bought this unit 2-3 years ago, they may have used it 5 times total. The other day I went to turn it on, and it clicks and powers off... I've changed plugs to ensure it wasn't a power issue, I also unplugged the unit for 5 minutes plugged it back in and attempted to turn it on, and the same thing occurred. There are no discs or tapes stuck in it either. Any help is appreciated!
epik559
  • 44 Answers
SOURCE: magnavox mwr20v6 turns itself off
The dry board is dead. or "power board."
Posted on Nov 25, 2007
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
SOURCE: DVD-R disc stuck in machine; powers on/off repeatedly
under the dvd player there is a lever you can slide with a knife and it will open it up
Posted on Aug 17, 2008
  • 3 Answers
SOURCE: Not booting
When the unit remains at the booting menu it is normally a sign that your Hard drive has failed. The hard drive in the wacs700 seems to run extremely hot, probably due to it's encaged location and poor airflow. It is possible to replace the drive yourself but it is fiddly.
You could send the unit back under warranty or get it repaired.
I charge £50 + cost of the HDD + postage to repair the fault.
No fix = no fee but you will need to pay for return postage. I only replace faulty Hard Drives and don't carry out other fault finding repairs. HDD Choices up to 300GB.
Robsony@btinternet.com
Posted on Aug 28, 2008
SOURCE: no power in magnavox mwd2205 vcr/dvd unit
how do i hook it up to a tv ?
Posted on Dec 12, 2008
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Flame won't stay lit
bobdukw,
This is a classic reddy heater problem. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 22, 2010 | Reddy RLP55V Utility Heater
I have a pioneer avic-f900bt and it keep turning off. it powers up for a couple of seconds and then it shuts off what could that be please help me.
I appear to have the same issue with mine. I purchased mine from Audio Itch in Tampa, Fl in December of 2008 and had them install it with an amp and speakers. Worked fine for almost exactly a year. Upon starting up my car, it powered up and gave the system powering up notice, then went blank. Rebooting with the small restart pinhole button sometimes works, but most of the time it will start powering up again, then shut off????
Mar 07, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
Panasonic SA-AK27 Bookshelf Stereo - Setting The Clock
Have you put on the eco mode? try this: power on the unit, click on the eco button, until the unit will display "normal"
Jul 07, 2009 | Panasonic SC-AK27 Shelf System
RCA D52W20 - turns on and off, blue screen, tech said need picture tube
It does sound like the tube, have the shop use a tube restoration machine to rejuvinate the tube, and replace the eprom to try to correct the no power down situation.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power
I had a similar problem with a Shop Vac. The solution was to disassemble the power switch and polish the metal electrical contacts to remove any oxidation caused from humidity. Tedious and time consuming but effective.
Dec 13, 2007 | Craftsman 17026 Wet/Dry Vacuum
Philips DVP3345V/17 DVD Player/VCR Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
