Question about Ford 8N Tractor
Ford 801 power master tractor cranks runs till its get warm up then quits
4 Suggested Answers
SOURCE: Ford 4000 TraCTOR WILL NOT START AFTER QUITING DURING BRUSH HOGIN
I had a similar problem. Does your acc red light come on when your key is on? Mine did not and I found out the hard way my positive battery cable wire was broken on the inside. I tested for power off the battery to all components. Everything tested OK. I was puzzled but, when I accidently touched just the cable to a component nothing.
Posted on Sep 19, 2009
  • 72 Answers
SOURCE: 84 ford bronco 351 runs good till warm then wont
It sound like you have a bad starter. When it is hot, it is drawing more amps than the battery can supply. You may also need to test the positive cable to the starter from the battery. To do this, you need a multimeter. Check the voltage between the positive and negative cable at the battery and note your readings. Then measure the voltage at the starter between where the cable connects and the case of the starter. Compare the two reading. If you have more than .5 volts difference, then the positive cable has too much resistance and needs replacing. Check for corrosion and make sure the cable is tight as well. I am betting on a starter though.
Good luck. Hope this helps!
Posted on Apr 09, 2011
skychief2001
  • 21873 Answers
SOURCE: Ford Taurus runs great till it warms up then shuts off and won't restart this is a 1995 taurus
A mechanic would check for voltage at the coil and the ignition module next.
Any trouble codes stored in the ECM ?
Posted on Aug 02, 2012
Have a 1999 Ford Explorer and it quits when it gets warm and will not start back till it cools down
Get Auto-Zone or Ford to run the codes for you. Might be bad MAF sensor or dirt in it. don-ohio
Mar 18, 2017 | 1999 Ford Explorer
Won't start
The carburetor isn't letting fuel into the engine. Check for a stuck float, a stuck inlet valve (attached to the float) or the fuel shutoff solenoid on the bottom of the Carb.
Mar 11, 2016 | Garden
Jul 31, 2012 | 1995 Ford Taurus
While driving vehicle just quit, like you turned
my one shot in the dark . fuel cut off located under passenger dash usely reset it or replace whole unit if you determin that its deffenatly the problem most folk that enconter this problem will try to keep cranking till they were down the battery, try a jump play with the fuel cut off switch,best i have to offer.
Aug 01, 2010 | 1995 Ford Windstar
Try jumping across the 2 large posts on the solenoid, if it cranks doing this, replace the solenoid
Aug 31, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Runs fine till warms up then losses power and dies
Does the fuel line still have 55 PSI when engine warmed up? Any other codes show up?
Aug 22, 2009 | 1998 Chevrolet Blazer
My 1991 crown vic runs great till it gets warm..about 5 minutes, then starts to flood out and wont start back till next day ...then same thing....help!!!!
if it starts to flood it may be the coolant temp sender. it could also be the crank angle sensor. hope this helps.
Aug 08, 2009 | 2005 Ford Crown Victoria
Engine quits after running 15 min
Hi..my name is Keith..i restore mostly old Ford tractors but i work on others...and this problem that you are having is kind of puzzling..but whatever it is..its either fuel or ignition..on the ignition side of it..i would suspect the coil or the condenser is breaking down when the engine warms up..and on the fuel side..i would suspect rust(trash) in your fuel tank and its stopping up your fuel line(which will need to be blown out with air)..or the fuel line is too close to a heat source and its vapor locking...i hope this will help..please write back if this doesnt
Apr 06, 2009 | Garden
Ford 8N Tractor Logo
188 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
