Question about Radio Communications
Why doesn't my cobra walkie talkie won't work after 2 mile
  • bahameelzipe Feb 27, 2012
    My model is two-way radio model CXT107 cobra micro talk. Can someone help me find the solution of why it doesn't work after 2 miles
  • 211 Answers
If you are referring to FRS or GMRS type radios, 2 miles is just about the maximum distance you will get out of them on normal terrain. Many of these types of radios will advertise claims of 10-15 or more miles of coverage. This type of "theoretical" mileage rarely if ever occurs in typical conditions. Many factors such as trees, buildings, hills and other "line of sight" obstructions will greatly reduce the effective range.
Posted on Feb 21, 2012
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Posted on Apr 09, 2009
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: we have lost manual for cobra microtalk walkie
I couldn't locate your specific model, but all of the Microtalk series radios seem to be basically the same as far as operations. Follow the link below to a manual that you can download/print -- it should work fine with your radios:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Bill B
Posted on Apr 18, 2010
micromatikal
  • 2777 Answers
SOURCE: have Cobra Micro Talk Walkie Talkies and have lost
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
Posted on Oct 12, 2010
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
HOW TO TURN ON COBRA MICROTALK PR 260 WALKIE TALKIES
you have to press & hold the "mode" button for a few seconds, same to shut them off
May 11, 2014 | Cobra Microtalk Pr260 2 Way Radios Walkie...
My cobra walkie talkie doesn't work after 2 miles
You didn't include the model number of the radios, but I suspect you're referring to Family Radio Service (FRS) / General Mobile Radio Service (GMRS) two way hand held radios. The FRS /GMRS types are limited to just 1/2 watt. Base GMRS type radios are limited to 5 watts. FRS is limited to Ch 1 - 14. Ch 15 - 22 are GMRS only, and require an FCC license to transmit. You can read more about FRS on Wikipedia.
Many FRS / GMRS two way radios claim incredible distances on the packaging. I've seen some that claim 15+ miles. Given the low power (.5 watt) that they are limited to transmitting, claims such as those would be under the most optimal of conditions. I can assure you that you or I would never encounter those conditions unless we were in some sort of radio laboratory / testing space designed to obtain these crazy distances. In other words, even in optimum "real world" conditions; these radio should only be expected to work when separated up to only several "unobstructed line of sight" miles (such as across open water of a lake, along a beach, etc. The range of these same radios will be reduced significantly when operated indoors, outside between buildings, where blocked by rocks, trees, metal, etc. The only reason you may have reduced range could be due to a power level selector switch that has been set to reduce the output power of the radio. Other than that, I think you'll find a couple of miles is about all you're gong to get.
Feb 20, 2012 | Cobra Radio Communications
We have lost manual for cobra microtalk walkie talkie & don't know how to turn on or use.
Bill B
Apr 18, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Radio Communications Logo
285 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
