Question about Canon Selphy CP400 Thermal Photo Printer
It won't pull the photo paper through
The printer will pull the paper up but not through my printer. I added more paper, but no luck. It worked fine for months and then today this problem. The message is "no paper" ...
    Problem Solver:
  • 6 Answers
I had that happen too. first make sure you dont have to much paper in the tray, and that the tray is locked in all the way. If these don't work uninstall the printer and then reinstall should work then
Posted on Sep 21, 2009
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
Won't load paper
Clean the paper feed with alcohol and a paper towel by rubbing and rotating the drum. Wait for it to dry completely then it should grab the paper. Also make sure paper is free from dust. Good luck!
Jan 25, 2013 | Kodak EasyShare Photo Printer 500
The photo paper does not grab in my hp photosmart c4180
Go to Control Panel, printer services or preferences. There is a quality tab there. I set it to Best. Then, I take a 1/4 inch stack of paper ad feather it to get some air in between the pages and it works fine. If the paper sits there for a while I have to take it out and feather a stack of it again, but that's all.
Dec 07, 2012 | HP Photosmart C4180 All-In-One InkJet...
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
My photo paper is loaded, but I have tried for an hour and it pulls in the blue tray, pushes it back out and says to load photo paper...I have removed paper, added, taken away, shoved the thing hard,...
have you taken and set the printer up to accept the correct size paper and did you load it in down? that should fix your problem, if not contact me and we/ll walk thru the proper sequence.
Dec 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Photo Paper Jams
Based on your question, my first thought is that you changed the type of photo paper you used starting "this week" (when you first posted your question). If you did, the photo paper size/thickness may not be compatible with your printer.
Otherwise, there may be a problem with the paper sensor. Click on the following link and review the troubleshooting steps, particularly Step 2, to see if that helps:
Paper Jam Troubleshooting
Post back your results. If you are still having the problem, post any additional information you think might help solve the problem. Thanks and good luck.
Sep 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper error
It sounds like the photo paper tray has gone in.Lift the paper tray and pull the blue photo paper tray all the way till it stops. Then push it back in till it clicks into place. Try printing again.
Let me know if it works
Jun 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Epson RX520 feed problem when using glossy photo paper
clean the rubber rollers that pull the paper. hoping it 2 work fine....
Jan 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Canon Selphy CP400 Thermal Photo Printer Logo
203 people viewed this question
old marine
old marine
