Question about Garden
Starts find gets warm up and quites - Garden
    Sergeant:
  • 316 Answers
Hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Posted on Feb 20, 2012
Engine runs fine. But it quits when I pull the trigger on the wand to start washing
Does this behavior change if the engine is warm and on minimum choke? Do you get any water spray before the engine quits? Carburetor could be dirty or float stuck. Try putting dose of carburetor cleaner through engine and cycle choke lever and engine speed lever back and forth while engine is running after it has warmed up without running water spray. See owners manual.
Apr 03, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
91 dodge d150 3.9 keep cuttung off replace fuel pump, fuel filter and relay
Does it quit, then if you sit for a while, re-start for a while again, then quit etc . warmed up, quits, then sits and cools then re-starts?
Nov 02, 2013 | 1991 Dodge D150
2001 suzuki intruder 800 vs quits running after warmed up
fuel blockage, check fuel tap and fuel pipe, check fuel flowing freely from carb drain screw
Mar 06, 2013 | Motorcycles
Quits after warm up wont restart
sounds like you have a fuel pump problem, fuel pumps will usually get hot and then shut off allowing it to sit 30 mins lets the pump cool down allowing it to start pumping, the way you can test it is get a can of starting fluid the next time it quits raise your hood and spray some fluid down into the throttle body and if it starts and then dies it is most likely your fuel pump, hope this helps.
Feb 02, 2013 | 1999 Dodge Dakota
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
LINCOLN 225 WELDER OLDER MODEL ABOUT 1985. 16HPENGINE. AFTER GETTING GOOD AND WARMED UP IT STARTS MISSING SOMETIMES BACK FIRES EVENTUALLY DIES. REPLACED COIL REBUILT CARB ,NEW FUEL FILTER AND LINES....
check plug and wire. you will want to do a compression test while you have the spark plug out and make sure you have no blow-by that will cause it to miss.
Oct 08, 2009 | Welding Tools
Crankshaft sensor?????????????????????????????????????help!!!!!!!
first thing to replace would be an overvoltage relay , do you have strange dash warnings too?
Jan 02, 2009 | 1994 Mercedes-Benz C-Class
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
