Mk-2063 keyboard not working
Instead of defaulting to the piano setting when I switch on, the keyboard is producing no sound at all.
  • cmelvillehov
    cmelvillehov Feb 20, 2012
    This is a musical keyboard, not a computer keyboard. Being put in the "keyboards and mice" category is probably wrong. I was given no choice.
2 Suggested Answers
SOURCE: BASE MK-939S KEYBOARD speakers issue
Either Speaker is open circuit or the amp is U/S. As this keyboard is Chinese garbage, if it's not the speaker then may the force be with you. Most of the chips in this piece of high tech (not) instrument are embedded in the small pc boards with epoxy coated over to stop moisture ingress.
Posted on Oct 14, 2011
Why do keys produce no sound?
Hi Kyle:
Have a look at your manual.
Sometimes you'll find that there will be an "input" setting required.
You might also try google with his link.
https://www.google.ca/#q=Williams+Allegro+88-Key+Digital+Piano
Hope this helps.
Cheers.
Oct 13, 2015 | Williams Allegro 88-Key Digital Piano
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
Download manual for mk980 electronic keyboard
This manual may work.
This device is a generic chinese product. It may be sold under several other names and brands.
http://acousticuprightpiano.sell.everychina.com/p-100967405-61-keys-teaching-electronic-keyboard-piano-led-display-with-rohs-certified-mk-980.pdf
Feb 12, 2015 | Computers & Internet
HOW TO USE TOUCH RESPONSE
There are two samples for each note in the "Piano" sound samples. This allows you to play "soft = p" or "Loud = f" based on how hard you hit the keys.
The default setting of 2 suit most people. You can change the touch response to 3 (more hard) or 1 (less hard). With tough response set to 3 - you play mostly the soft samples until you bang the key much harder.
This is a keyboard that tries to give a bit of effect that an acoustic piano hammer mechanism would give.
Oct 29, 2012 | Casio Lk-110 Keyboard
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Dec 17, 2008 | Cakewalk Music Creator 4
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
