I don't have display
Start Works, but does not display
  • ceramicsaeed
    ceramicsaeed Feb 21, 2012
    The problem is fixed
    One of the reasons Capacitors Motherboard swollen
    Thank you
  • Computers & ... Master
  • 27,725 Answers
You will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Posted on Feb 21, 2012
  • ceramicsaeed
    Thank you
I have an 07 Susuki Reno. The oem radio works, but the display don't. Anything I can do, other than replace it?
that radio is your vehicles security functions and other functions
replacement is major important now here in arizona there is a place called dannys oem sterio repair
new radios have a security key that the dealer would have to reset so no matter what your going to dealer to set the radio or your car wont start if replaced
Mar 04, 2013 | Motorsports
An alarm sound just started going off. I don't know how to make it stop.
my toshiba laptop is working but dont coming display so please help me
Jan 22, 2013 | Toshiba Computers & Internet
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
When turned on it has no picture but sound works
hello!
if your TV stays on, display glows, but there is no picture, most likely you have faulty t-con board and/or display itself. I've encountered the problem with both lately. I'd start with t-con(display adapter) board. it's not hard to replace and cost around $100 top. If that won't solve the problem, then it's a display panel itself. not an inverter, which is the part of power supply, but panel itself. Before replacing t-con, try to reach display's ribbon cable connectors, plugged into t-con board. disconnect first one and turn set on. If you see half of the picture, the display is bad.
If nothing changes, reconnect that cable and disconnect another one. If you see half of the picture, display is bad. If, still you don't get any picture, that's your lucky day! Display is good, t-con is bad. Replacing the display panel will void any reasonable repair option. Those crooks at "parts distribution' selling displays at the price of your TV, when you bought it: $1,500-2,000+. i don't understand why do they practice rip off. most likely to encourage customers to buy new junk and receive hefty bribes from "peoples republics" to stay in business. Anyway, it's a crazy globalism. that's why our country in default.
good luck with your project,
thanks,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
Purchased this recorder about 6 months ago. Now it can't turn off via the hold switch.A very sleek and convenient piece of apparatus. When I try again after 2 days it works fine but when i try to turn...
It is possible there is an intermittent contact, but I don't believe there is anything to worry about.
The HOLD slider does not turn off the recorder. It only turns the keyboard off and the display off as well. The clock keeps running.
A simple test?
Start a RECORDing operation and slide the switch to HOLD.
(In my VN-1800 the keyboard goes dead, but the display stays on.)
(In my DS-330, the keyboard goes dead and the display goes off.)
If I slide the switch to HOLD during a PLAYBACK operation, it keeps going until the file has finished playing. Then it goes blank.
May 31, 2011 | Olympus VN5000 (512 MB 3005 Hours)...
Sony nwz-b142 doesn't display in my computer. I already tried installing the device in the control panel and it says device works properly and yet it doesn't display in my computer
This advice could help you if your player works properly and the problem is in your pc only:
At first you should be sure that your USB cable can work.
Then let's see the PC.
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
gylacz
May 03, 2011 | Sony Walkman NWZ-B142 MP3 Player
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
