Question about Transtherm Ermitage Wine Cooler
Is this unit NSF approved for commercial restaurant use?
I found a 2004 kitchen mixer KSMC50S it says no attachments for this model although it has the gear and it spins. Any help appreciated.
The reason for the sticker is that the mixer is NSF certified.
The attachments are not rated for commercial or restaurant use, hence the sticker.
Of course, the attachments will work perfectly well with your mixer as they do with my KitchenAid KSMC50.
Dec 04, 2017 | Food Mixers
Where to buy mabe gas stove burner parts
Not sure what area you live in but check the yellow pages under restaurants/ equipment repair. You will find a local repair company that will sell parts and should be able to help you repair it as well.
Jun 24, 2014 | Blodgett Kitchen Ranges
I have a BKF-8W-8" commercial
JES Restaurant Equipment - JES RESTAURANT EQUIPMENT Wholesale
I would bet that if you took the old unit out by loosening the bonnet from the assembly, any local hardware could supply the part for you.
Gary
Aug 17, 2011 | B&K Plumbing
I need UL and NSF certification proof for Hoshizaki KM-900 MAF Ice maker. Can please provide?
http://www.hoshizakiamerica.com/manuals/KM-900M_F_inst.pdf
This is the manual for your machine. Check out the pages that have examples of the nameplate information. It shows that the machine is approved for UL and NSF. Otherwise, I would suggest contacting Hoshizaki directly.
Dec 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
One of my customers had a goodman vsc060 compressor installed and I wanted to know if that is used in commercial also and how reputable of a unit it is compared to trane or other well known names.( His...
Goodman is are decent (builders grade) equipment. Not as good as Trane or Carrier but if it's installed correctly it should be fine. Goodman is mainly a residential brand but they do make some light commercial equipment which again is decent as long as it is put in correctly.
Mike
Jul 09, 2009 | Heating & Cooling
Transtherm Ermitage Wine Cooler Logo
Top Transtherm Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Transtherm Furniture Expert? Answer questions, earn points and help others
