Question about Whirlpool Dishwashers
WHIRLPOOL DISHWASHER MODEL DU920PFGQ0
CONSOLE BUTTONS DO NOT OPERATE. MY DAUGHTER, ELLEN SITTER, CHATTED ON LINE WITH YOUR TECH BENIMUR ABOUT
THIS PROBLEM. HER COMPUTER KEYBOARD FROZE UP AND
SHE WAS UNABLE TO TYPE IN THE MODEL NUMBER
  • mickeiser Nov 25, 2008
    Some of the buttons on the touch screen don't work. What can I do?
    Brigadier General:
  • 6,966 Answers
Appreciate the information. Actually I am in contact again with needgurufast (Ellen Sitter?) and she has posted on the extension of the Live Session. Although no longer real time, we have exchanged additioanl information. There was just a hitch that the model number she eventually posted does not show up and could probably be a misstype, an O for a 0, a B for an 8, G for a 6 or a Q.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 29, 2008
I have just recieved a Whirlpool model DU920PFGQ3 and I installed it, however it will not turn on and I have checked everything. The power line connection and the outlet and everything is great. Is there a reset button or something?
Posted on Jun 20, 2009
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I need the reset button sequence for a Kenmore Ultrawash automatic dishwasher Model # it is 665-15772990. My daughter was playing with all the lights and the only thing it will do now is drain.
I had the same problem and this fixed it:
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 14, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Normal wash cycle constantly blinking no other buttons responding dishwasher wont start
one of 3 things is happening, either your "start" button is not funtioning, the door latch is not operating, so the uint doesnt recognize the door closing there fore wont operate, or the "normal" button is "stuck"( electronic switch possible shorted)
the fact that you cant get any other function out of it leads me to believe that you have a stuck button/shorted keypad. this is not available as a seperate part and requires replacing the "console with active overlay"
Mar 03, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
yes i have had this problem most likely a console/touchpad assy
Sep 27, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
303 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
