Pc board burnt
Machine not switching on. have 220v on the supply but nothing switching on.
  • 32,281 Answers
If the motherboard is burnt then it is not repairable. You need a new motherboard or a new laptop. The better choice would be a new laptop.
Posted on Feb 21, 2012
I accidentally plugged in epson nx110 to 110v when i shoudl have plugged it in 220v , burnt smell and no power at all
Not sure why it burnt going from 240 down to 110volts. The unit should not have worked. However, if it is a 110 volt machine and you plugged it into 240 volts... different story... At best you have blown the power supply board or board fuse.. At worst, the machine will be fried inside.
Aug 09, 2011 | Epson Perfection V500 Flatbed Scanner
Burnt Power Supply
You can try replacing the fuse in the power supply if it has one. Most have a permanent circuit breaker that once tripped, the power supply is no more. If you can change the fuse, there's a 90% chance it still won't work since there was a burnt oder, which indicates the fuse didn't blow fast enough to prevent more damage, like the motherboard.
May 11, 2010 | Dell Vostro 220 Desktop Computer
Burnt Power Supply
yes it is possable to repare this but it is fiddle and eats times i would advise the user to perhaps look on ebay for a cheep inport if this is not acceptable to the user then there are guides on google how to .... hope this is of some use
Mar 18, 2010 | Dell Vostro 220 Desktop Computer
Line 6 Spyder 112 got plugged into 220v now just smokes.
The power supply is bad. The transformer more than likely survived however some fuses and possibly filter caps could have been blown. Also some of the regulatory circuitry for switching or digital lines could have been damaged. This being said you should be able to get the amp working again without any problems.
Jan 09, 2010 | Music
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Our minolta 4000 copier machine is 110v supply but we here have 220v supply,kindly tell me what kind of changes i have to do in the supply board of machine to run on 220v supply with out adding additional...
You would not be able to modify your existing 110v power supply. You would have to have a 220v power supply. This would be nearly impossible to find tho as this machine is now more than 10 years old. I'll see if I can dig up a part number anyway just so you can do some searching.
Dec 13, 2009 | Office Equipment & Supplies
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
Need to chat with an agent!
1. make sure not only those are properly seated on the led portion of the the case and on the motherboard..
2. also check your power supply motherboard connector is properly seated on the mother board
3. and make sure your power supply switch is on the right postion (110v/115v North america or 220v/230v Europe)
4. make sure the wall outlet plug is working properly. and properly connected to the back of the powersupply
Dec 04, 2008 | E-Machines eMachines Desktop PC
Foxconn motherboard red light and nothing else
Remove all connectors and cards except vga and power supply. and one stick of memory and start there.
If its still an issue remove the board from the case , it may be shorting out on something and try it outside the case,
check the power supply switch for 110/220v switch on back if it has it.
to manually trigger the power supply on the 24 pin connector
short the green and black wire that is next to it.
Jan 26, 2008 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
