Question about Charging & Starting Systems for Jeep Cherokee 2 Door
My jeep cherokee 2.5 CRD has no pulse at the injectors as a result it is just cranking
I recently had my jeeps starter and glow plugs changed, the mac left the battery out for 2 weeks and now the car wont start. I have no pulse at the injectors. pressure is good. already checked the cam sensor and crank sensor, checked all the wiring no problems with that. but the car just cranks. any help please
  • 7 Answers
SOURCE: alternator for 2005 jeep limited grand cherokee
you can log on to autozone.com and find the exact alternator that you need even a battery, and its pretty easy to replace i just reciently replaced mine by myself, it only takes about an hour if you have the tools
Posted on Feb 08, 2009
russet327
SOURCE: 1996 Jeep Grand Cherokee No Start
I would be thinking that there is a good chance that you need to be checking out replacing the computer, if you aren't getting any communication with the proper scan tool then the computer isn't communicating with anything in the vehicle...... I would have guessed first off that the ignition control module might be bad but that is obviously part of the computer also, I would be looking in that direction.
Posted on Sep 19, 2009
  • 1168 Answers
SOURCE: 93 jeep cherokee country 4.0
Hello crichardson.
OK, here are all the things to check for.
Spark on all ignition wires,
compression test all cylinders,
ignition timing,
good fuel(not old or contaminated),
injectors firing (have voltage pulse).
Is the crankcase flooded with fuel? Smell the oil. Drain it if it's full of gasoline and put in fresh oil.
I have seen spark plugs that have been flooded that won't fire, even if they look clean.
If the distributor cap and rotor are old...toss them, they are cheap to buy new. Old ones can crossfire internally and rotors can short to ground.
Putting your fuel pedal to the floor while cranking shuts off the fuel injectors. This is called "clear flood mode"
I am telling you this for two reasons.
One that it may be handy to get it started and two to tell you that a shorted throttle position sensor can cause a no start.
Are there any codes stored in the computer? If there is, start there. It may lead you to your no start issue.
There you are, a few ideas, I hope that one of these helps get you running again.
Thank you for using FixYa.
KL
Posted on Nov 28, 2010
xtrasharp
  • 14 Answers
SOURCE: 97 jeep Cherokee sport no start turns over but no spark on fuel an no gages work what could it be already changed crank sensor
sounds like a crank sensor to me it is located on the bell housing of the transmission on drivers side near the top
Posted on Feb 05, 2015
Testimonial: "tryed"
ricktnkc
  • 18 Answers
SOURCE: 99 jeep grand cherokee cranks but wont start replaced crank sensor new fuel filter ..still wont start pressure is good please help
that's tough luck sounds like the computer is bad to me
Posted on Feb 16, 2015
There is no power on my injectors for my jeep cherokee sport 2.5 crd 2003
I am pretty sure that the crank sensor is what fires the injectors. Make sure the sensor is good and that it is receiving the signal from the flex plate.
Mar 13, 2018 | Jeep Cherokee Cars & Trucks
2002 jeep Cherokee 2.5 crd cannot get engine management light to go off
Check the ASD relay ! powers injectors .Located in the engine compartment power distribution center ! ASD auto shut down relay . Very common problem .
Apr 18, 2016 | Jeep Cars & Trucks
2003 land rover freelander wont start
could be the glow plug or the glow plug relay. when you turn the key and hold at number 2 do you hear a click after a few seconds ? should hear a click.... after you hear the click start the engine.
Feb 05, 2014 | 2003 Jeep Liberty
2004 jeep cherokee 2.5 crd fails to start. glow plug light does not come on. Engine cranks, so battery is fine
Gotta be a fuse. I see it all the time with diesels. It's usually somethin you can take to dealer and have fixed in five minutes
Aug 04, 2013 | Jeep Cherokee Cars & Trucks
2004 jeep grand Cherokee fuel injectors stay open
If not pulsing, could be a bad pcm. The computer grounds the injectors internally for a split second to pulse them . If trash or debris is not making them stick open, buy a "noid light" for checking injector circuits. Plug it in to #1 or #5 and crank engine over: if circuit is working right, noid light will be blinking. If light is on steady, computer is not interrupting ground to cause pulsing.
Jul 11, 2013 | Jeep Grand Cherokee Cars & Trucks
I changed my glow plugs on my free lander and now it wont start
How about the glow plug controller was it tested and it supplies power to the glow plugs?
Nov 04, 2012 | Cars & Trucks
2004 Jeep Grand Cherokee CRD 2.7L injector seal leak issue
I would contact the dealer and see if the parts dept has a revised seal.
Jun 14, 2012 | Cars & Trucks
Vehicle Parts & Accessories Logo
90 people viewed this question
Top Jeep Vehicle Parts & Accessories Experts
David Burbee
David Burbee
Thomas Perkins
Thomas Perkins
Andrew Gaitan
Level 1 Expert
Are you a Jeep Vehicle Part and Accessory Expert? Answer questions, earn points and help others
