Question about Acer Computers & Internet
Hi i have windows 7 & just purchased a perixx wireless keyboard every time i hit the shift key the caculater pops up most annoying how do i disable it for ever. many thaks alex
    Genius:
  • Acer Master
  • 1,274 Answers
Open the keyboard software and find the hotkey menu and disable it. should be self explanatory. let me know if you can't find it
Posted on Feb 21, 2012
Why is my Perixx PERIMICE-712B Mouse only working intermittently after only 7 months?
Because it is a no name mouse with little or no warranty. You're lucky it worked as long as it did.
May 15, 2014 | Perixx PERIMICE-712B, Wireless Mouse for...
Thespacebarwon'twork!HELP!
did you try to pop the space bar off and clean it and put it back on it should work then
Feb 05, 2014 | Perixx PERIDUO-703W, Wireless Keyboard and...
Hi, i have a fujitsu siemens v6535 with windows 7 ultimate & my wirless switch doese'nt work, it may be broken, i tryed every way to turn it on from windows(fn+f1 & other ways) ???? how ca
Have you tried turning it on manually? Look on both sides and in front of the laptop for the switch.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 10, 2012 | Computers & Internet
I have a Logitech cordless ex110 keyboard that I would like to find an online manual for....I have no idea what the 'F' keys do and every once in a while I hit something (?) that converts my /,...
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
The manual and other documentation for the Logitech ex110 is available here: http://www.logitech.com/en-us/433/154?selectedcrid=433&selectedcid=154&WT.z_sp=Product&osid=&bit= .
I hope this helps.
May 20, 2011 | Logitech Computers & Internet
My compac preserio cq 41 has no backslash key and other keys are not as shown @ key and " key are opposite when hit the shift key back slash key shows ### the 3 key shows ££ when...
Start / Control Panel / Date, Time, Language, and Regional Options / Regional and Language Options / Languages / Details
you probably have "English (United Kingdom)" installed instead of "English (United States)" or vice versa.
Jan 04, 2011 | Compaq Keyboard
How do I shift to the blue key functions on the keyboard
I've run into this a lot myself and personally find it annoying more than useful. While typing, your punctuation keys suddenly switch to their french functions. By defaul, Vista assigns a keyboard shortcut fo changing input languages.
This shortcut is ctrl+shift - a very easy combination to press by mistake. To solve this problem, just press crtl+shift until you're back to english. You can change this shortcut or disable it all together.
Open the control panel then click "change keyboards or other input methods" under "clock, language and region". In the window that pops up, click "change keyboards..." then select the "advanced key settings" tab. This is where you can edit and disable language related shortcuts. To change one, click on the profile and then click "change key sequence". Under "switch keyboard layout", select "unassigned" to disable that shortcut.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
My number keys arent working because i was hold shift for more than eight seconds the a message popped up then i clicked ok
Try holding down the shift key again for 8 seconds and read the window to cancel the filter keys.
As for your numbers not working, there is a NumLock [number lock] key on your keyboard. Try hitting that and see if your numbers work.
Hope this helps.
shibumi
Jan 26, 2009 | Targus USB Ultra Mini Keypad Keyboard...
HP Laptop keyboard fails... sporadically
I suspect your problem may be caused by the wireless keyboard, even if you are not using it. You may be using your computer in a "noisy" environment where the wireless transceiver is picking up random signals and corrupting the keyboard interface. Or the wireless keyboard driver could also be at fault.
Can you de-install the wireless keyboard from your system and see if the problem occurs again?
NOTE: I had weird problems with my Microsoft wireless mouse until MS came out with an updated driver for it.
Nov 25, 2008 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
