Question about AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD DVD+CDRW COMBO BEATS DEAL (NEWITEM24231814) Motherboard
Computer shutsdown completely when i insert my 80gb seagate barracuda 7200 HDD
Well for now im using 10gb sony hard disk (poor me) it works fine, because i can't use my 80gb.
PROBLEM:
When i insert it in slave or master it dont boot even the asus splash screen wont apear the cpu fans are off, the monitor are in standby mode (blinking light)
"I even think that maybe the POWER SUPPLY is the problem because last month i found a dead baby rat inside the power supply while im cleaning it"
So please can anyone help me? Dear Experts... T_T
Tnx in advance!
~Cedie
  • 3 more comments
  • Cedie94
    Cedie94 Oct 28, 2008
    Im using "Windows XP Pro sp2"
  • Cedie94
    By the way im just a 14 yr old do not have that kind of knowledge of inner parts of the computer.
    But i will try it. Umm can you please give me a clearer explaination? But anyways tnx for the effort of helping me... ^_^
  • Cedie94
    Sorry its AMD ASUS A7V8X-X not amd asus a7v8x-mx i noticed that i clicked the wrong m/board... T_T
  • Cedie94
    Cedie94 Oct 29, 2008
    I can't because when i turn on the computer with the 2 hard disks connected, the computer immediately turns off so i cant hit del or go to the bios settings because the computer is off.But when i connect the 10gb hard disk i can go to the bios settings it doesn't turn off.
    We try to use the warranty to repair the disk. but the technician said it has no error. He suggest that we change the os or format the disk. And in their computer it worked but ours don't work.
  • Cedie94
    My problem has been solved...
    The problem is the Power Supply it's corroded due to the dead rat i found last month.
    Solution:
    Buy a new one. ~_^
    I say thank you very much to colliewob for being there give me some guides and effort to help me. TNX!
  • 781 Answers
What operating system are you using some can only recognize up to 10GB
and is the 80GB fitted correctly
stripe on cable to No1 pin on M/board socket and toward the 4 pin power socket on hard drive
Posted on Oct 27, 2008
  • 1 more comment
  • David
    David Oct 28, 2008
    Try resetting BIOS to default then check the 2 hard drives are recognized by the BIOS.if not try entering the CYLS Heads etc for the second one
    I still think you could have it connected wrong
    The stripe on cable goes to the 4 pin power plug on hard drive.
    Sometimes it only connects one way others it can go either way
  • David
    David Oct 28, 2008
    To reset the BIOS remove M/board battery for 5 minutes.
    it is a round shiny object about 20mm across check how it is held in. then replace it
    your BIOS should then be set at default
    Or when booting at the lower left side of screen should be words similar to this
    "to enter bios press DEL F2 or similar key"
    When in BIOS read directions carefully to set to default then to set hard drive settings
    If this fails to recognize hard drive it is probably bad
    If you can try in another computer
  • David
    David Oct 29, 2008
    The only thing I can suggest is you have somehow connected it wrong
    You should have 2 hard drive connectors on M/board
    1) for original hard drive set to Master and CD set to Slave
    2) spare get a new ribbon cable and fit to M/board stripe side to No1 pin then connect cable to 2nd hard drive set to Master and try.
    Also if new hard drive is a SATA one unless setup properly it will not work with and IDE one
    Sorry cannot help further if I was there could probably fix it
Hi I have a Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache.It runs fine for a bit then it just diconnect itself,so you have to scan for hardware or you have to reboot the system.Is there a fix for...
Test your HDD (Hard Disk Drive): go HERE, click Downloads and download Seagate Seatools for DOS (free). Burn the ISO to a CD, set your 1st boot device = CD drive and reboot with the disk in the drive. When the tester loads, choose the Quick Test in the upper left corner of the screen. It takes 5-10 minutes and will give you a pass or fail. If it tells your that SMART has tripped, or gives a fail notice, your drive is failing. You should have a warranty on that drive with Seagate.
If the drive passes as good, change your data cable. I have seen bad cables cause problems. Also check the power cable.
If you still have problems, enter Administrative Tools\Disk Management. Find your drive, Right click on it, and click "Mark Partition as Active".
If still no joy, try changing the SATA port on the mother board that your drive is plugged in to.
If still no joy, contact Seagate customer help, they are very good.
Oct 08, 2013 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
I would like to get a HDD with more memory.
You can buy 80GB or 160GB, nothing is incompatible with Hard Disk, unless you buy another kind of Hard Disk like a new one SATA or check your Motherboard, it tells there what kind of HDD you put it in. There are two HDD that you can buy in the market one is IDE type & SATA.
Aug 06, 2009 | HP/COMPAQ - 260755-001 (260755001) Hard...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
My seagate barracuda 7200.7 st380011A 80gb when i use it as primary haerd dist operating system is not supporting it but when i use another hard disk as primary and it as secondary it is properly working....
i think you must place a jumper on the back side of the hdd.
If there isn't any jumper, it is a "slave".
When you place a jumper on the correct spot, the hard drive will become the master hdd. The position of the jumper can be found on the hdd itself.
Search for "master" and put the jumper there
Jun 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
Jan 14, 2008 | Computers & Internet
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
145 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
