Question about Canon imageRUNNER 5020 Copier
I have a jam problems with code 020f - Canon imageRUNNER 5020 Copier
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Bios backdoor password needed.locked out of bios. can you help?
For those with Fujitsu Lifebook specially with PhoenixBIOS never remove your CMOS battery no matter what happened.Or else you cannot used your laptop forever....You will surprised 100% with these message
Warning
020F: PASSWORD LOCKED: Fixed Disk 0
F1 resume F2 Setup
So beware...
Jun 13, 2009 | Dell Inspiron 1501 Notebook
Always paper jam
there is so many reason for that
where the jam when u try to copy 1 copy
Apr 24, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
Sharp Copier AR-C270 Code Problem
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
Canon imageRUNNER 5020 Copier Logo
80 people viewed this question
old marine
old marine
