Zenith Z56Z98D8 rear projection......HELP!!!
Hey again... Thanks for the quick reply!!! Just a couple more
questions.... Is a "bleeder assembly" the same as a "HV splitter"?
Would the part# for this bleeder assembly be A-17813-01? Is part #
A-17196-03 a bleeder assembly a substitute bleeder part or something
totally different? How comfortable % wise are you that this is my
problem? Unless I'm an idiot, the noise I hear is coming from this
particular part. Sorry for the additional questions, it's not that I
don't appreciate or trust your expertise, cause god knows it's WAY WAY
more than what I have, I just want to be as sure as possible before
spending $$$.
Thanks again, greatly appreciate it!!
Steve
I am unable to adjust the red color in the convergence adjustment on my IQC50H94W 2000 Zenith 50". From everything I read I believe I need to replace my Convergence IC Chips, however I am not 100%...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 24, 2011 | Zenith IQC50H94W 50" Rear Projection...
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
Feb 10, 2009 | RCA P56923BL 56" Rear Projection...
Your reply to the Samsung 47 inch rear projection not turning on
As long as you do not accidently solder wrong connections together you should be OK. Make sure all solder is to same circuit.
Jan 07, 2009 | Samsung HCL4715W 47" Rear Projection...
its called a bleeder assembly www.partsstore.com has a replacement for it 172.00 That could very well cause of the HV modules problems.
Oct 27, 2008 | Televison & Video
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Need replacement convergence panel for 40"zenith rear projection hdtv. repairman took part and money, then ran. please help
can you verify the model number of your Zenith and i will try to assist you. reply to this same post.
Jul 24, 2008 | Televison & Video
Follow up to JUL 9th distorted picture question
That would be the convcergence ICs and feed resistors that need replacement. Can you reply to this same post and verify that your model is the R56W36? I will then post the correct ICs and feed resistors for your model as well as a link where you can get replacement ICs and resistors with free instalation instructions with pictures.
Jul 14, 2008 | Zenith R56W36 56" Rear Projection...
Mitsubishi personal code entry
mitsubishi vs5004r need code(10 digit)
May 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Chassis
And what was the symptom of what your set was doing?
Mar 04, 2008 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
