Question about Panasonic TH-50PV30 50 in. Plasma Television
Intermittent turning itself off
I have had the set for 4+ years - until recently it was a great unit........BUT..... it now decides to turn itself off intermittently. When it does the remote won't work and it has to be restarted via the on/off switch on the tv. When it restarts it sometimes won't work and other times it does. On the back of the set there are 4 fans - the cover surrounding the one on the far left (when looking at the back) gets hotter than the others although it keeps working. Any advice would be appreciated.
  • spiros2 Oct 27, 2008
    Thanks salt1976, it was one of the first things I checked---------- problem still persists.
  • srocca Apr 12, 2009
    We have the same problem with our plasma...possibly may be a fan not working and switching the tv down
Check your setup menu and make sure that turn off timer is off
here is instruction below on your tv
hope it works
panasonic.com.au/content/library/files/F000518.pdf
Posted on Oct 27, 2008
We recently purchased a darby dehumidifier-#DDR6009EE-60 pint- and have not been able to program the equip.Can you help us. We need to know how to adjust it so that it will go on and off after specific...
I beleive there is some confusion about the Timer Mode. It can only be set to turn the unit OFF after a selected time period. For example: It's 6pm you want the unit to turn OFF at 10pm. You press the Timer button on the unit itself, in increments, until it reaches 4 hours. At 10pm the unit will turn OFF. As a safety feature, it does not have the capability to turn the unit ON at a selected time and then OFF again. In the interim, until you get really familiar with all the functions of this model, use the control pad on the unit, rather than the remote control.
I hope this helped you understand what the timer does and how to activate & set it.
Jul 15, 2011 | Danby Dehumidifiers
I have had the Whirlpool GOld dehumidifier for 4 years. It was working great. Recently, I noticed that it stopped working. When plugged it, it trips my GFI socket. I have tried various outlets and checked...
Obviously, there is an electrical short within the unit. Should it be repaired? Yes, if you want continue using it. But, is the cost of troubleshooting, finding the necessary part and repairing it worth it? Most of the time, the cost to repair a dehumidifier is about the same, as what a new one would cost. Now, if purchased an extended warranty, when you originally bought the unit 4 years ago, then you're probably covered for the repair.
In the end, the decision is yours to make.
May 26, 2011 | Whirlpool Dehumidifiers
Hi receiver is having intermittent problems with power up & off. at the moment it would only turn on once in 5 times i try to turn on. At one stage it would turn off but then back on again within five...
I got Yamaha RX-V3800 with intermittent power.
Cause by capacitor C4 22nF 630V on the control power board.
After replacing the capacitor, receiver again working OK!
Feb 13, 2011 | Yamaha RX-V3800 Receiver
Completely Wacky 'Sansa e260'
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. That will be the only way
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
Ws65711,8 years old, working great with out problem until this one..turned off the tv normally after use, then when tried to turn on again... it turns on (green light turns on. no pictureno...
SD TECH,
Just started experiencing convergence problem with my Mits ws-65711. I have decided to try to repair on my own and have the service manual. I see also you have step by step instructions for the repair and perhaps photos of the fuses. I could really use this info if you are able to provide.Thanks in advance. I did the self check by holding in MENU and INPUT buttons and got 1 green blink followed by 2 shorter/quicker green blinks?
Aug 30, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Samsung HLP5063W turns itself off
rither the lamp door cover switch, or the thermostat has become intermittent..neither one is very expensive but soldering skills are needed
Nov 25, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Panasonic TH-50PV30 50 in. Plasma Television Logo
356 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
