Question about Garden
Where can I get a replacement fuel cap for my strimmer
    Sergeant:
  • 316 Answers
Hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ^^
Posted on Feb 20, 2012
Restring a pgt300 performance power strimmer, it has a white casing which does not come off preventing me from adding more line
There should be 2 plastic tabs which you have to push in, this removes the wider outer base cover of the strimmer spool, giving you access to the bump cap and line spool.
Depending on the style you have, one looks to be a whole replaceable spool unit, one looks like a re-threadable spool.
If you find this useful, please click the 'helpful' tab. Thank you
May 14, 2016 | Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Spear & Jackson 33cc Petrol Grass Strimmer SGT33N, black fuel pipe split. How to replace it?
empty the petrol,feed the black line (the fuel intake) into the tank and grab the end of it thats attached to the filter inside the tank. now you can feed a new fuel line through into the tank and reattach to the filter. hopefully this will solve your problem ive just done this but mine still wont start, either flooded or spark plug. by the way i bought mine new and the fuel line was split.
Jun 05, 2013 | Garden
Mcculloch mt270 strimmer cuts out when I press the trigger
Carburetor needs replacement. Possibly primer bulb assembly as well.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 26, 2012 | McCulloch Garden
I need to replace the cutting cord on my Flymo Contour 500 XT strimmer but cant get the cap off, please advise
the cap has left hand threads so to loosen it turn it like you would tighten most other bolts
Aug 07, 2012 | Garden
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
How do i change the line on my bosch garden strimmer, as it has broken
As it was impossible for me to get cap off spool I used a screw driver to prize off lid. If i ever need a new garden strimmer I will never ever buy this model again. It was so frustrating I felt like throwing it over the fence and buying a black and decker one.
Aug 03, 2009 | Garden
2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
May 04, 2009 | Garden
Primer bulb not filling
Yes, I think the gas cap may be clogged. The gas cap must be able to breath, otherwise this vacuum will occur. Try starting your trimmer and when it starts to choke out, loosen the gas cap. It should get air back in the tank, then and keep running. If this works, clear the hole in the gas cap, or purchase a new one.
Jim
May 03, 2009 | McCulloch 26cc Gas Blower Mcb3208
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
