Question about Garmin GPS
Ic 1792a-01278 garmin - Garmin GPS
New battery installed and fully charged but still will not turn on
In that case you have either a faulty USB socket or the unit has suffered a voltage overload and has internal chip ic damage
Apr 10, 2014 | Garmin NUVI 765T 4.4 in. GPS Receiver
The display has hosizontal lines and/or lines with missing content. Hardly readable. Anything to be fixed?
Hi:
This is an indication of a bad display driver IC, it is better to just replace the unit as you probably will not be able to get parts for this unit.
Apr 17, 2011 | Garmin Fishfinder 100 GPS Receiver
HI. Where can I find the model for my GPS? I says Garmin Nüvi on the front, on the bottom it says FCC ID: IPH-01278 IC: 1792A-01278 MT102 10R-023994 Thanks, Nina
If its the 600 or 700 series its located on side on Serial Number where you hook it to Suction Cup Mount
Love my Nuvi760
May 29, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 360 says "updatin ps software 0%" on start up and then won't be able to acquire satellites
This indicates that there is a problem with the flip-up antenna/GPS receiver assembly and there is no communication between the main board and the GPS receiver IC. When this happens, you won't be able to pick up satellite reception.
The main board is trying to upload a fresh copy of the GPS firmware stored on your Nuvi but it fails because of the problem in the GPS receiver assembly.
Please see this link for more info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Dec 31, 2009 | Garmin NUVI 360 GPS Receiver
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
MY GARMIN 765T SAT NAV WILL NOT CHARGE.
Your Garmin is not charging then it is a loose contact or cold solder in charging socket. That is the common problem of socket you must re works the solder there or bring it to a cellphone repair if you are not electronically enclined. If re solder does not fix then problem is in the charging IC. Replaced this IC so it will charged again.
Good luck:
Don't forget to rate:
Jul 08, 2009 | Garmin nuvi 765T GPS Receiver
Chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Jun 16, 2009 | Garmin GPS
Garmin 50 forerunner failure
It sounds to me as you are having the problem with faulty contacts. They should be cleaned and checked for stiffness- if too weak must be replaced.
The next possible cause can be integrated circuit (IC) failure. In this case only skilled watchmaker can help you and that gonna be costly.
Dec 16, 2008 | Garmin Watches
Garmin Nuvi 200
how unlock garmin 2000
Dec 30, 2007 | Garmin nuvi 200W GPS Receiver
GPS Logo
258 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
