Question about RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset
Blackberry 655+ driver
I have a laptop with Window 7 and I'm trying to install the 655 like headset with micro to substitute the normal cable headset with micro, but window show an error that cannot find the driver. Do you have any suggestion? Regards, Giovanni Pippia
3 Suggested Answers
jerseymark
  • 358 Answers
SOURCE: From today my blackberry bold
Anyway, with regards to your issue, error 523 reset means a "System process died" You'll need I would reload the entire hand held OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the Black Berry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
But, since this has happened so many times, I have to ask myself, is it something you're doing that it causing this? I know the Red Pearls from AT&T have had issues from DAY ONE!
Posted on Oct 11, 2010
ZAHRAKOLLAM
  • 70 Answers
SOURCE: my device shows app error
CHECK YOUR USB CONECTOR OF PHONE MAYBE IF DAMAGE
CHANGE YOUR USB CBLE
CHANGE USB PORT OF YOUR COMPUTER
Posted on Dec 06, 2010
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
Inverted web cam display in asus k401j
1. Download the latest Chicony (or Suyin) driver for Windows 7. Check here: http://support.asus.com/Download.aspx?SLanguage=en&m=Camera&p=3&os=)
2. Extract contents to desktop.
3. Click the ORB button. right-click on Computer and select Properties.
4. Select Device Manager.
5. Click on Imaging Devices to show the name of the webcam.
6. Right-click on the name of the webcam and select Properties.
7. Go to the Driver tab. click on Update Driver. a new window should pop-up.
8. Click 'Browse my computer for driver software'. select 'Let me pick from a list of device drivers on my computer'.
9. On the next window, it'll give you the current driver. click 'Have Disk'. click Browse. Browse to the desktop and select lastest driver that you've downloaded. it'll be then added to the list of drivers. select the new driver and click Next. Just follow the prompts so that it'll install the new driver.
If still this does not work, try this:
Re-install the camera virtual camera using your ASUS hardware disc and follow this step.
1.Insert ASUS hardware disc and "open"
2.Click "explorer"
3.Click "software"
4.Click "camera", then choose and click chicony folder
5.Open the folder APPLICATION/installer, and re-install the ASUS virtual camera.
Once you already installed the driver, go to start menu click or type ASUS lifeframe then open it.
Jun 25, 2011 | ASUS Computers & Internet
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Tips & Warnings
Good luck to you..
Feb 01, 2011 | Cell Phones
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Need passkey for the hs-655 pleasee!!!
All bluetooth earsets have a universal passkey which is 0000 or 00000.
That should do the trick.
Aug 12, 2010 | RIM BlackBerry 8100 HS-655 Bluetooth...
Remote funtions on LG HBS200 do not work with Blackberry Tour
When you go into the Tour's Bluetooth options, you can view which services are available for each paired device. Check the headset's properties and make sure all of the available services have a check mark next to them.
If that doesn't solve the problem, let me know and we'll try to find another solution.
Oct 05, 2009 | RIM BlackBerry 8100 HS-655 Bluetooth...
RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset Logo
152 people viewed this question
Top RIM Radio Communications Experts
eradiostore
eradiostore
Are you a RIM Radio Communication Expert? Answer questions, earn points and help others
