Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Work station pe120i takes long time to warm up
Need drivers for Windows 7 for my xerox workcentre pe120i
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
Sin cartucho
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 10, 2011 | Xerox PE120i Laser Printer
My 1989 gmc sirrea 350 set the timing replaced the tps map and idle control valve idles great just hesitates on take off what could cause this
At first thought mine would be a dirty throttle body. This is the area just below the throttle plate. A good cleaning could help out. Do this after the enging is warmed up then shut off. Dissconnect the battery, yea I know you will lose radio stations, but as a saftey issue. Take a rag with carb cleaner , open the throttle and wipe it off with the rag. Really works on Chrysler products.
Michael A.
Jan 18, 2011 | 1989 Chevrolet Celebrity
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Drivers won't load for xerox pe120i and new windows 7 install
This is NOT an uncommon problem with Windows 7. Many manufacturers have not updated the existing drivers for compatibility with Win-7... they want to sell new hardware! If the drivers that load automatically from Microsoft do not function properly then check on the Xerox site for updates - an email to customer support may help if you don't find new drivers on their site.
Feb 17, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
Xerox PE120i not answering - phone line tested ok and fax 'rings' but doesn't 'pick up'. Set to answer after one ring. Anything obvious to check please?
make sure its on the line in plug not line out. test a fax out to you other phone (doesnt have to be a fax)to see if it rings
Oct 15, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Soft copy of the printer
The guides can be located at Xerox.com under documentation. They can be downloaded easily
Jun 03, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
No Cartridge error message on Xerox PE120i
The cartridge's sensing is bad or either the cartridge is refilled one (then u need to replace the crum)
omnipresent
Nov 04, 2007 | Xerox PE120i Laser Printer
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
