Question about Garden
2003 yardman snowblower model 1k072130048 30 - Garden
    Sergeant:
  • 316 Answers
Hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ``
Posted on Feb 21, 2012
I need a new sparkplug for my yardman snowblower 31600 series. I lost the manual and don't know the proper plug to get.
Pull out old spark plug and take to auto parts store, They can cross reference number on spark plug. I have good luck with NGK plugs
Nov 13, 2016 | Garden
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
I can't find the choke lever for my Yardman model number 31A 285 452 Snowblower, and I can't get it started. Any suggestions?
Here is a link to a parts diagram of your blower.; Part # 12 is the choke.Parts diagram choke location
I hope this helps. Please post feedback.
j
Dec 09, 2013 | Garden
Owners manual for yardman snowblower model 31ae993i401
Here is the link: http://www.manualslib.com/manual/108091/Mtd-31ae993i401.html
Nov 17, 2013 | Garden
Yardman snowblower model 31ae99i401 parts list
http://www.mtdproducts.com/equipment/OperatorManualView?storeId=10500&catalogId=20500&langId=-1
Attach snowblower yardman lawn tractor
most likely not unless...
Oct 03, 2013 | Garden
1995 Yardman 7 hp Snow Blower wont start. Ran fine last year and I drained the gas out. I cleaned out the carburetor, (tecumseh HSK70) 632371A. The top screw was 1/8 out from closed and bottom screw...
my 7 hp tecumseh yardman snowblower wont shift into gear worked fine but shifted hard (20 below) then wouldn't shift at all (loose) I noticed a rod that goes through the area where it shifts is loose (not connected) what is this rod. thanks for your help.
Jan 21, 2011 | Yard Machines Garden
Yardman snowblower will not shift properly
you must been the arm back. look under your unit and check the drive rubber wheel. your are going to probably need to adjust the shift arm assay. make sure you lube all slide shafts. let me know
Oct 18, 2009 | Garden
Problem with snowblower electric chute
This was poorly designed , you will have more problems unless you fix it right as the bolt heads underneath the shute ring is rubbing the right stop and on top of the motor housing the main problem is the left ring stop is hanging up on the front motor mount.
to fix it,remove the motor,grind about 3/16" off the rear shims and file about the same off the bottom of the front motor mount,remove the motor mount bracket,file about 1/4" off of the right stop,remove the shute and the shute ring, mark the left stop before removing,bend the left stop up about 3/16" be careful not to bend the ring,replace motor bracket first than shute ring and shute than replace motor.if your shute has hung up often you may need to replace the motor,you can go to an auto parts store buy a 1999 chevy lumnia passenger side window motor around $50.00 vs yardman $360.00 you will need to tap out the mount holes with a 5/16 standard thread tap and tap from the bottom of the motor,don't forget to file the bottom of front motor mount.
Jan 18, 2009 | Winter Sports
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
