Question about RTO Ho Herpa Freightliner Truck Tractor
How do you change a steering wheel in a freightliner columbia
2 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: steering wheel removal instructions for 2005
you will need a specel tool so you will not cut your horn wire that comes up through the shaft,I made mine and the bolts that go in the steering wheel to pull it off are metric,if you need a pitchure of it I will email it to you,wilsodfarm@yahoo.com
Posted on Jul 30, 2009
Code icu 140 columbia detroid engine
I googled: icu 140 columbia detroit engine
There are a number of answers. They should help.
May 07, 2015 | Freightliner Columbia Dash Panel: 2002...
ABS LIGHT IS ON ALL THE TIME
I've had that problem too even changed the abs switch, the best thing to do is put duct tape over the switch on ur wheel
Feb 11, 2015 | Freightliner Columbia & Century Class 120...
Abs light is on all the time sometimes I get a code
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
Replacing expansion valve
following the line connected from the front mounted condenser to the compressor pump at front of engine , it's mounted in that line ,(small) use extreeme caution as theres a lot of pressure there on that line , fyi if your expansion valve is plugged your compressor is bad as well!!
Aug 31, 2014 | Freightliner Columbia & Century Class 120...
Freightliner fault codes list128
check your water level. if ok then clean your water temp sensor or level sensor
Aug 17, 2014 | Freightliner Columbia Dash Panel: 2002...
06 freightliner columbia sm codes on 12 speed smart shift
2005 freightliner columbia smart shirt does not take a gear and code shoes up sm.
Apr 24, 2012 | 2007 Ford F-650
Steering wheel removal instructions for 2005 freightliner columbia
Jun 30, 2009 | RTO Ho Herpa Freightliner Truck Tractor
RTO Ho Herpa Freightliner Truck Tractor Logo
460 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
