Question about Kirby G6 Bagged Upright Vacuum
Kirby G6 Power Switch Test ?
B0sslady2001
Hi, Guys,
I have a G6 here that just stopped.
1) popped open the power cord cover & plugged in a standard heavy duty 'din' cord- still D.O.A. (It's own Pwr Cord had contiuity but did a double check anyway)
2) Dis-assmbled (needed a clean anyway) bench mounted motor & switch assembly with front activator button tape to 'on' position and held the 'boot link' slide in the forward position while cycling the on/off switch,- still did not start.
Question: IOs their any other test I should do before ordering a replacement power switch ?
Regards
Mac
  • jasonwood66 Mar 27, 2009
    I have a G4 with the same problem; I just need a service manual and I can't seem to find one. Anybody want to help???
  • Kirby Expert
  • 324 Answers
You can look at the wiring diagram and try to figure out how to use a circuit tester to test the switch but I would just suggest just swapping it for a good one (always good to have one good switch for testing) and see if it solves the problem.
Good Luck
Rocky
Posted on Oct 30, 2008
I have a Kirby G6 and I plugged it in and there is no power to the machine. I checked the power switch in both spots by the boot and the front by the head and still nothing. I tried a new cord and nothing...
Its been awhile since I pulled one of those apart but I had a similar issue with a G and the power switch assembly that sits beside the motor had failed. Its a modular piece that (if memory serves correctly) operates main power and the emptor safety switch. This was the issue with a machine I had in to service.
Oct 05, 2017 | Kirby Vacuums
Splicing kirby electric cord
If you are unsure on how to splice the cord back together it may be best to just purchase a new cord. You can find a new G6 cord and it is easily installed into the switch at the base of the Kirby.
Kirby G6 Power Cord
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Kirby Generation 3 Bagged Upright Vacuum
My kirby G6 2000 no pwer
More than likely you have a short in your power cord. however if you want to know for sure take machine apart until you can put an elec meter on switch where cord is attached. plug machine in and test the end of cord that is attached to switch if you have 120volts at that point its your switch thats bad. if you have no voltage or anything less than 110volts at the switch replace cord
Jan 14, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Mar 15, 2010 | Kirby G4 Bagged Upright Vacuum
Plug in kirby vac to do the floors and it won't start.
It could be the power cord or even the switch. I suggest taking it to an authorized Kirby repairshop and have it looked at. It could be something as simple the power switch
Aug 25, 2009 | Kirby G6 Bagged Upright Vacuum
Our G3 Kirby will not power up?
Either the cord or the switch is bad. The cord is simple. Take the tab screw on the back of the machine off and the screw holing the cord cover off. Pop off the cord cover un-plug and remove then reverse steps to replace. If it is the switch that is better left to proffesionals so call your local vacuum shop.
Apr 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G6 won't turn on.
If the brushead is removed,there is a safety switch which prevent the machine from operating if the brushead is removed or not installed correctly.Either this switch or the main power switch could be the culprit,as well as the cord.
Dec 13, 2008 | Kirby G6 Bagged Upright Vacuum
Hi! I'm interested in purchasing a G3 model ; however , the seller says that the machine was working perfectly and then when switching power on a while later , the machine was " dead " . Other...
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums, I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 15, 2008 | Kirby Vacuums
Kirby G6 no power
Could be the switch, I would check the cord 1st. It has 2 wires running thru it, one may be open. That power cord goes bad often, if anyone is pulling on the wire rather then the plug, then it would have have stretched and break.
Jan 15, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
636 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
