The dishwasher trips out the main RCD at the fuseboard when it gets to the point whne the water is hot i.e. producing steam. I assume that the steam is getting into the electrics somewhere, but cannot work out where. Has anyone else come accross this problem?
I had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Posted on May 22, 2008
It may be the element has a tiny hole in it somewhere, I had the same problem, and found a minute pin hole under some corrosion on the element. This was allowing the power in the element to circuit to the metal casing, and trip the RCD, but only just enough to trip it, not enough to show on my DMM. Hope this helps.
Posted on Feb 22, 2007
Sep 15, 2016 | Bosch Dishwashers
May 19, 2015 | Stoves Dishwashers
May 12, 2017 | Ovens
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Jul 30, 2009 | Washing Machines
Nov 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Oct 21, 2008 | Dishwashers
Aug 07, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Jun 07, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
677 people viewed this question
