Question about Samsung Televison & Video
Samsung LCD LE32C450E1W tv Vertical lines.
Samsung LCD LE32C450E1W tv. Main board BN94-03982B Power board CN07BN4400338ASE38Z8P1421. The set works fine on digital tv and on HDMI1. When analogue (off air) tv or HDMI2, 3, Av, or Component is selected vertical lines begin to appear on the left side of the screen and continue to spread to the middle and on to the full screen. The lines get narrower and after 15 minutes the picture looks with a white fog or haze across the screen. The lines have have thinned out and merged together to form a haze. The thin white lines then display a faint grid with a faint dot in the middle of each square on the grid. The picture can be seen behind the haze. When the set is put into standby for thirty seconds and restarted the lines are gone but begin to grow from the left again .
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
jerryg50
  • 1667 Answers
SOURCE: Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Posted on Apr 17, 2008
SOURCE: RCA flat panel L42FHD37 When first
You can easily fix this audio problem by downloading a software upgrade for your HDTV. And you don't have to be a rocket scientist or a brain surgeon either ;)
If you need to find the software upgrade:
Go to RCA.com and click on Support, from there you will click technical support. In technical support, click on the link called Software Download. Scroll to the bottom of the page where you will find 2 links. The first link will tell you how to download the software to a Mini Cruzer USB drive (you need at least 15MB of space) and the second link is the software download itself.
Posted on Dec 10, 2008
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
  • 14 Answers
SOURCE: Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Posted on Oct 14, 2009
Vertical and horizontal lines on samsung plasma tv
Check the Vs and VA voltages to plasma panel. If these voltages, that comes from the main power board is abnormal, this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 19, 2016 | Samsung Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Vertical lines
You will most likely need to have the set diagnosed. Vertical lines can be the result of a defective t-con board, faulty lcd panel/t-con connections, or a faulty panel itself. Do the lines stay or do they come and go? Older Samsung sets are known for faulty LCD panels!
Oct 20, 2013 | Samsung LN46B640 LCD TV
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
Samsung LE32C450E1W there's a red thin line going
try tapping your finger on edge of the screen where the line starts/ends... it works for me... its a lose connection normally with the rubber seals that have connections in them that lead to the circuit boards inside.... try it and let me know...
Feb 10, 2012 | Samsung Televison & Video
Hi = My LG5010 has developed vertical lines on the right hand side - if I move the screen backwards and forwards, the lines go away, but as soon the TV is switched off and on again, the lines come back. ...
The problem is most definately the LVDS cable that goes from the Main board to the Tcon board. The main board is the large one in the middle of the set and the t-con board is at the top- middle of the set. The connector is a long skinny plug with usually 20-25 pins. The connector can be unpluged (carefully) and cleaned with alcohol and a q-tip. There is NO VERTICAL Chip in any LCD or Plasma sets. Vertical circuits of that design have been gone since the inception of DLP, LCD and Plasma sets. The last analog set rolled off the line in 2005.
Sep 25, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a 46" samsung lcd television that will power up but only displays vertical lines in a variation of colors
Vertical colored lines usually means a bad panel. At the least it might be the t-conn pcb (a board connected to the panel). You might get lucky and just unplugging and replugging the LVDS cable (its a thin computer cable with lots of wires that goes from the main board (it has the audio and video plugs on it) to the t-conn board. You usually push in the clips on each side of the connector to release it. good luck! Panels cost more than the TV did.
Feb 23, 2010 | Samsung LN-T4665F 46 in. LCD Television
Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
Jan 22, 2010 | Samsung LN46B640 LCD TV
Vertical lines have appeared on my LN46B640 LCD TV When I turn it on, the picture is clear at first, and then over a couple of minutes vertical (predominately yellow) lines appear over the image.
if this tv is under warranty i would call samsung, there could be three board that could be going out on it one is the techon board, main board, but you also my need the ip board changed out to. i repair samsung all day long and i see this problem a bit.
Oct 12, 2009 | Samsung LN46B640 LCD TV
Televison & Video Logo
562 people viewed this question
Henry  Thomas
Henry Thomas
